Old 08-20-2019, 03:32 PM   #1
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post)
Just saw this posting on r/ft86 referencing an issue with the inlet camshaft timing distributor (sic): "Well. I'm working for Toyota Europe. Yes, i am one of those guys who's changing your valve springs. Today during my 18th Recall, i faced an issue. While controling the valvetiming i realized that the timing-distributor, doesn't lock properly. If i had mounted it like that, (like one guy somewhere in this country did) it would have caused some massive enginedamage."
Has this already been brought up? Not sure if it's a new issue or not.
thanks
https://www.reddit.com/r/ft86/commen...news_everyone/
MJones_RB is offline   Reply With Quote
Old 08-20-2019, 04:01 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
I work on cars every day, and don't have the first clue what's circled in that picture. Other than the end of a camshaft of course.
maslin is offline   Reply With Quote
Old 08-20-2019, 05:29 PM   #3
MJones_RB
MJones_RB's Avatar
This is the only reference to this in the shop manual. Weird.
Old 08-20-2019, 06:17 PM   #4
maslin
Benz Tech
"Long story short: There is a chance that there will be another Engine related recall, since it is a production error. In the picture above you can see the rear side of a Inlet-camshaft-timing-distributor. Inside the red Circle is a plate with the lock-spring behind it. That Plate may loosen up while doing the Valve spring recall, risking massive engine damage
EDIT: THERE IS A CHANCE THAT THERE WILL BE A RECALL. I WON'T PROMISE THERE WILL BE ONE. but at the current state we are at 4 broken distributors in 400 cars which have done the recall by now."
So he's a mechanic and he's taken it upon himself to determine the fault and announce that Toyota will be issuing another engine related recall?
Sounds like a bit of a reach to me. I went through and fixed his typos, I could barely get through 4 sentences.
And I still don't get it. The plate is clearly still intact, what is the pending catastrophic engine damage coming from?
The Following User Says Thank You to maslin For This Useful Post:
MJones_RB (08-20-2019)
Old 08-20-2019, 07:10 PM   #5
MJones_RB
MJones_RB's Avatar
Sounds like he's a mechanic who shouldn't be working on Subaru engines.
The Following User Says Thank You to MJones_RB For This Useful Post:
maslin (08-20-2019)
Old 08-20-2019, 08:33 PM   #6
MJones_RB
MJones_RB's Avatar
May be related to this:
[ame="https://www.youtube.com/watch?v=e7jg63RtWqo&t"]https://www.youtube.com/watch?v=e7jg63RtWqo&t[/ame]
Old 08-21-2019, 08:35 PM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
This was one of the major reasons why I sold the my FR-S. I got the CEL with the error code for Cam Shaft Sensor...wasn't the sensor, costed me me around 1300 WITH Toyota assistance and dealership assistance to fix one sprocket. Didn't feel comfortable owning the car after this.
The Following User Says Thank You to N1rve For This Useful Post:
MJones_RB (08-22-2019)
Old 08-22-2019, 10:28 AM   #8
gravitylover
While they had my engine apart they found 2 camshaft sensors that were bad, one apparently rotted and the other sending inconsistent signals as well as an oil control valve was bad. The tech that is doing the work seemed fully confident that he had the problems solved and they covered the parts and additional labor time so hopefully he's right. I'll get better info when I go to pick the car up (hopefully) today.
The Following User Says Thank You to gravitylover For This Useful Post:
Old 08-22-2019, 01:17 PM   #9
MJones_RB
MJones_RB's Avatar
Good luck! Let us know how it turns out.
gravitylover (08-23-2019)
Old 08-22-2019, 04:00 PM   #10
That backing plate only needs to stay in place until the sprocket assembly is mounted to the camshaft. Otherwise, if it, the valve plunger and spring are set aside, they can all go back together just fine.
It is NOT the port for the center lock. You have to go way deeper to get to that. It is a related mode switching valve.
This has been covered in the past but all I've seen is misinformation. Look for item 13 on the functional diagram.
https://demos.starbase7.net/t3Portal...0558A001X.html
maslin (08-22-2019), MJones_RB (08-22-2019)
WTB: Camshaft Timing Oil Control Valve Assembly Connector driftking96 Want-To-Buy Requests 8 05-18-2022 07:02 PM
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Camshaft timing oil control valve assembly - P0013 smellslikecurry Issues | Warranty | Recalls / TSB 8 11-02-2016 09:53 AM
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 11:38 AM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
