Old 08-20-2019, 01:31 PM   #15
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Vital View Post
So, i have this wheel in 17x8 on 245/40/17 and lowered on RCE Yellows. I think it looks great and very OEM+ and functional. If i had do it again i'd just go 17x9 because with the 8" wheel rear with the drop it is slightly sunk in. Regardless i still love the way it looks. I can try to get you pictures later.
Please do post pics! For 17x8 I'd recommend using 225/45 instead of 245/40 though.
As for how 17x9 looks, there's a different thread for that:
https://www.ft86club.com/forums/showthread.php?t=134142
The Following User Says Thank You to timurrrr For This Useful Post:
Will BRZ (08-20-2019)
Old 08-20-2019, 02:35 PM   #16
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
It'll definitely poke if you stay stock and it'll look bad too massive 4x4 status lol. The problem with 9" and stock struts up front is that its too close to the spring perch. The rears will have no issue of course. Now, you remedy the poke by adding camber, but i honestly dont think you'll be able to run much camber if any with that size wheel, tire, and that offset. If you are thinking about lowering definitely get some camber bolts for the front though.
Thanks yeah I’ve seen the lifted BRZs haha I’ll definitely be lowering it with springs and adding camber bolts at the same time that I get the wheels mounted. If I absolutely have to, I’ll get LCA in the future, but honestly minimal, natural camber is fine (I think I’ve seen like 1.5 to 2 degrees all around)
Will BRZ is offline   Reply With Quote
Old 08-20-2019, 03:12 PM   #17
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Will BRZ View Post
... I’ll definitely be lowering it with springs and adding camber bolts at the same time that I get the wheels mounted...
The problem with 17x9 +40 is that you might not have enough clearance from the suspension strut in the front to get any significant camber with camber bolts.
Old 08-20-2019, 03:56 PM   #18
Will BRZ
Drives: 2015 BRZ
Oh okay thanks. Guess I’ll go with the 8s if I go with the Dekagrams. Thanks for the info
Old 08-20-2019, 11:02 PM   #19
Vital
Drives: 2015 BRZ
Yeah pictures would be great because Im going for a similar setup thanks. I just feel like the 9s would poke a little bit. I’d rather it be sunken in a bit than to poke
Yes, i've read all about the 225/45 vs 245/40 i've not experienced any ill effects of using that tire size. Personally i think its all subjective. Anyway, here are the pics sorry im a n00b and dont really know how to upload pics... Hopefully this helps others to see the with fitment with an approx. 1" drop.
The Following 2 Users Say Thank You to Vital For This Useful Post:
mrg666 (10-12-2019), Will BRZ (08-20-2019)
Old 08-20-2019, 11:14 PM   #20
Will BRZ
Drives: 2015 BRZ
https://imgur.com/oJGIhSb
https://imgur.com/lAIf99x
https://imgur.com/TQ3T7fH
Wow that looks really good dude. Better than I thought honestly. Anything else other than springs? Would you happen to know the camber specs? Seems like the 245 fill up the wheel well pretty well and I would imagine it’s comfortable too. Maybe a 235 tire would be a happy medium. Thanks man that really helps my hunt lol
Old 08-21-2019, 10:33 AM   #21
Vital
Drives: 2015 BRZ
Thanks man! Yep, just springs on stock shocks for now. Camber bolts up front and rear lower control arms thats it. Yes my camber up front is -1.6 and the rears are -1.4 with slight toe-in. The 245/40 fit pretty nice in the wheel wells once lowered, but having lower offset will help too. I think ride comfort some what depends on the aspect ratio of the tire as well generally lower profile tires will not get you a comfortable ride.
The Following User Says Thank You to Vital For This Useful Post:
mrg666 (10-12-2019)
18x9.5 +35 Konig Dekagram (Squared) adelbertray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 08-20-2019 11:19 PM
Konig Dekagram 17x9 18BrzBlue Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-02-2019 05:20 PM
Should I get 17x9 w 40 off or 18x8.5 w 44 off both konig dekagram Bread1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-26-2018 01:26 PM
Konig Hypergram 17x8 +40 TheMOPs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-18-2017 12:03 PM
FS: 17x8 Konig Runaway w/ 225/45/17 Continental Tire racing slicks LI/NY st0k3d Wheels and Tires 11 09-21-2014 12:19 PM
