| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2014 BRZ - WRB
Konig Dekagram 17x8 +40
Noticed there weren't too many photos available of the Dekagrams on the brz so I thought I'd upload a few photos. They are 17x8 +40 on stock suspension. Tires are Continental Extreme contact sport 225 45r17. Konig lists the wheels as 16.83lbs. Let me know if you have any questions!
#2 |
Drives: '13 Scion FR-S & '17 Toyota 86
The wheels and tires look great!
Now she just needs a drop! |
#3 |
Country Boy 4 Life
Those Konigs look nice on your BRZ. There really isn't a better deal on decently lightweight wheels!
I LIKE TIRES! |
#4 |
#5 |
#6 |
Drives: 2017 BRZ PP , 2005 Saab 97X
Im a huge fan of the movement Konig has been working on, they've really pushed to get their name out there, and I like em a lot. Ill probably get a 17x8 when the time comes for really sticky rubber, ill retire my 18x8 to street duty
#7 |
Drives: 2018 BRZ
Konig lists these at 16.83 lbs, did you get a chance to weigh them before mounting to see how close the specs are? I'm curious if these would meet the SCCA Solo Spec Coupe rules. 17 lb minimum for a 17x8.
#8 |
Drives: Jeep 75th, Porsche GT3RS, BRZ tS
Will these clear the brembo brakes from the performance package?
#9 |
Drives: 2022 GR86
Sadly, Konig Dekagram 17x8 +40 will NOT clear BRZ Performance Package Brembos.
It will touch the edge of the caliper that's closest to the hub. See the black scratch from the wheel on the caliper on the photo below. A 3mm spacer might be enough, but I didn't have one to try, and I personally don't want to use spacers.
#10 |
Drives: 2022 BRZ, Red
Any chance to see if these wheels will clear the AP Sprint BBK?
#11 |
Damn that's crazy...
Drives: 2015 BRZ
This size looks so good on stock suspension. I’m sure it would look even better with a minimal drop. Do you, or anyone else, have more pictures of this wheel on the car? I’m really debating between 9 and 8 width for this wheel. I’d really like the 8s for weight savings and 225 tires, but I don’t want the face to change like with RPF1s. Thanks
#12 | |
Drives: 2015 BRZ
#13 | |
Drives: 2015 BRZ
#14 |
Drives: 2015 BRZ
It'll definitely poke if you stay stock and it'll look bad too massive 4x4 status lol. The problem with 9" and stock struts up front is that its too close to the spring perch. The rears will have no issue of course. Now, you remedy the poke by adding camber, but i honestly dont think you'll be able to run much camber if any with that size wheel, tire, and that offset. If you are thinking about lowering definitely get some camber bolts for the front though.
| 18x9.5 +35 Konig Dekagram (Squared) | adelbertray | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 08-20-2019 10:19 PM |
| Konig Dekagram 17x9 | 18BrzBlue | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 08-02-2019 04:20 PM |
| Should I get 17x9 w 40 off or 18x8.5 w 44 off both konig dekagram | Bread1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 01-26-2018 12:26 PM |
| Konig Hypergram 17x8 +40 | TheMOPs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-18-2017 11:03 AM |
| FS: 17x8 Konig Runaway w/ 225/45/17 Continental Tire racing slicks LI/NY | st0k3d | Wheels and Tires | 11 | 09-21-2014 11:19 AM |
