#15 | |
Drives: '13 FRS - STX
There's about a half inch of suspension travel before you engage the bumpstops and with <200# springs that half inch disappears pretty damn quick. |
#16 |
Dismember
Drives: 2013 Red Scion FR-S
I don't see any real advantage to cutting the bump stop. The suspension is designed around using it in most cornering. It's a progressive spring system, and a pretty good one at that.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | strat61caster (07-15-2019) |
#17 | |
Depending on how you cut the bumpstops (such as cutting from the softer or stiffer end), you change the overall spring/bumper system in different ways. But they're designed as a complete unit. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#18 | |
Interesting. I’ve done bad spring selections on other cars and ended up riding the bumps and it was obvious and handled like trash. I didn’t realize the Twins road the stops by design. My Integra was twitchy and unpredictable on the stops. Then again the stops on that car were rock hard compared to the ones on the FRS. If I didn’t have the dust covers on I’d throw some zip ties on to see how far they climb just out of curiosity. |
#19 | |
I have a theory as to why manufacturers are doing this but just a theory. - Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | strat61caster (07-15-2019), wparsons (07-15-2019) |
| FS: 2017 Springs/Bump Stops | Drambeenie | Brakes, Suspension, Chassis | 4 | 06-10-2018 02:42 PM |
| Different bump stops came with my RCE Yellow springs | kuangxtc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 12-19-2016 08:07 PM |
| SWIFT Spec R Springs - Bump stops | project d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-03-2014 08:25 PM |
| Lowering springs and bump stops survey | solidONE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-27-2013 11:23 PM |
| Swift Springs: Cut OEM Bump Stops? | BillY2KFRC | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-22-2013 01:45 PM |
