Old 07-09-2019, 04:46 PM   #1
juniorrr
Drives: Scion Frs
Recommended Rear Differential Fluid for Automatic?
Hi guys so im at 60k miles now and i thought it would be a good time to change my rear differential fluids and i was just wondering what do you guys recommend for an Automatic? (IF auto even differs from the manual)
I haven't felt any issues with the rear differential so i was wondering at what intervals should it be serviced at?
juniorrr is offline   Reply With Quote
Old 07-09-2019, 05:38 PM   #2
86TOYO2k17
Drives: 2017 toyota 86
Same as manual.
Either
Motul Gear300 75w90 Synthetic
Or
TriboDyn 75w90 Synthetic
It’s pretty quick and easy. Not sure interval but a 20minute 35$ job. Might as well do it.
Old 07-09-2019, 07:08 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I used Mobile 1 gear oil.
All depends how much money you want to spend or which fan boy brand you want to use.
Old 07-09-2019, 07:20 PM   #4
86TOYO2k17
Pretty much any 75w90 synthetic gear oil can work really. But I wouldn’t worry about trying to save 10$ on a cheaper product for something that you only do once every 50k+ miles. Maybe if you do hardcore tracking and swap out fluids frequently it’ll add up.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
humfrz (07-09-2019)
Old 07-09-2019, 07:57 PM   #5
juniorrr
Drives: Scion Frs
Yeah I think ima go with Motul I hear its one of the best. Thank you guys for recommendations. I also need to get the two crush gaskets as well from toyota. Do you guys know the torque specs by chance for these the Top plug and Also the bottom plug?
Old 07-09-2019, 09:18 PM   #6
How about till the crush washer is crushed, then, another 1/4 turn (just for good measure - ).
Bubba
Mr.ac (07-10-2019)
Old 07-10-2019, 03:23 AM   #7
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
I guess. I'm not on the Motul bandwagon. So my fan boyism is showing.
Besides Motul sucks fat ****.
Mobile 1 all the way.
As for the torque spec I think it's like 30 something ft/lbs. but I would take humfrz way. That's the way I "torque" mine.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (07-10-2019)
How To: Change your Transmission & Differential Fluid StaggeredHorizons Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 06-01-2019 09:41 PM
Differential Fluid Change Drain Plug - 10k & 40k BRZ_F Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 01-04-2018 11:25 AM
Changing Differential and Transmission fluid Seabass47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-20-2017 01:21 AM
factory differential fluid warning hankster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-28-2012 03:49 AM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
