Old 07-06-2019, 07:08 AM   #15
abec
Drives: 2019 Series Grey, 2016 FRS RIP
Originally Posted by Yoniyama View Post
What about the end links? Longer end links are needed to match the 10mm higher ride height.
Where to find longer end links?
stock ones worked fine.
abec is offline   Reply With Quote
Old 07-08-2019, 11:28 AM   #16
Racecomp Engineering
Originally Posted by abec View Post
I couldn't find any data on the stroke of the standard shocks. Above is the data on the TRD rally stuff though.
Looks like stock stroke, thanks!
- andrew
AndMsc (09-19-2021)
Old 08-07-2020, 07:02 PM   #17
abec
The TRD rally suspension lives again!
It took longer than I planned, but I have once again installed the rally TRD rally suspension. This time in a 2019 Series Grey BRZ.
Due to the larger Brembo's on the Grey I needed better brake clearance. Enkie Sport RC-T5 are true Tarmac wheels. The 17x8.5et45 with 245/40r17's fit perfectly.
My experience with the handling characteristics of the TRD Rally suspension on the FRS lead me to decide against using the TRD Rally Struts, and instead opting to use the SACHS performance package struts as they felt significantly better than the OE FRS struts and valved better for the kind of driving I do 99% of the time.
upload images
The Following 7 Users Say Thank You to abec For This Useful Post:
Dzmitry (03-26-2021), grumpysnapper (08-08-2020), Racecomp Engineering (08-07-2020), Spankopotomous (03-27-2021), Stonehorsw (04-02-2021), Thaeyo (12-16-2020), whataboutbob (03-26-2021)
Old 08-07-2020, 08:25 PM   #18
Nice wheels! I'm planning on a set in 15x6.5.
Also glad you got another GT86.
- Andrew
Old 08-10-2020, 03:11 AM   #19
Turdinator
Señor Member
Turdinator's Avatar
Do the TRD struts and shocks come with different bump stops or do you re-use the stock ones?
1974 TA22 Celica
2013 86 GT
Old 09-11-2020, 11:22 PM   #20
abec
- Andrew
If the Series Grey didn't come with these damn brembos I would have gotten them in 15's as well.
90% sure it came with them. I can't find the photos of the full contents of what came in the box though.
The Following User Says Thank You to abec For This Useful Post:
Turdinator (09-13-2020)
Old 01-22-2021, 01:46 AM   #21
Turdinator
Señor Member
Turdinator's Avatar
I picked up the TRD Rally suspension also. I am still waiting on some other parts before I can install them so I thought I would get some shock dynos done.
Purple is TRD Front
Green is TRD rear
Red is the stock rear (We ran out of time before they could run up the stock front I had)
1974 TA22 Celica
2013 86 GT
The Following 4 Users Say Thank You to Turdinator For This Useful Post:
abec (06-27-2021), grumpysnapper (01-22-2021), N234 (01-22-2021), whataboutbob (03-26-2021)
Old 03-25-2021, 11:51 PM   #22
Turdinator
Señor Member
Turdinator's Avatar
I installed my TRD rally suspension over the weekend. I used pedders offset strut tops in the front with some camber bolts, Anderson Design and Fabrication 1" strut spacers all around and 215/60R16 tires for a fair bit of ground clearance. Contrary to what is mentioned earlier in the thread, with new oem rubber isolator between spring and strut top, the springs were definitely captive. I cut 1/2" off the front bump stops and 3/8" off the rears to give things a little more room to move.
Initial driving impressions are quite good. The tires I have are like balloons but taking that into account it corners pretty well, it's definitely not wallowy either but does still soak up bumps pretty well.
I have taken it on some dirt roads but the part with corners was closed due to flooding so I will reserve my thoughts on dirt road handling for another time.
1974 TA22 Celica
2013 86 GT
The Following 5 Users Say Thank You to Turdinator For This Useful Post:
Alfs (04-10-2021), Capt Spaulding (03-27-2021), churchx (03-26-2021), grumpysnapper (03-27-2021), whataboutbob (03-26-2021)
Old 06-27-2021, 07:44 PM   #23
abec
That makes sense, I am using Raceseng camber plates, which would be the reason I don't have a full capture on the springs.
Old 06-27-2021, 07:59 PM   #24
abec
Also as an update, I will say, I am very happy with the TRD rally spring paired with the SACHS performance package struts. It's a great fit for mostly driven on tarmac backroads on low treadwear summer tires.
The Following 2 Users Say Thank You to abec For This Useful Post:
jrhudson (06-27-2021), Turdinator (06-27-2021)
Old 06-27-2021, 11:27 PM   #25
jrhudson
Drives: 2016 scion frs
It's weird but i recently had an inkling to take my FRS camping haha. The wife will take the 4Runner, but I never thought about taking the FRS on dirt roads or anything bumpy.
This is something to think about now.
jrhudson is offline   Reply With Quote
Old 06-27-2021, 11:42 PM   #26
Turdinator
Señor Member
Turdinator's Avatar
That is something I've hoped to do now that I am lifted. Unfortunately the covid restrictions where I live have made it tough. I can say that going from lowered 1" to lifted almost 2" has been an awesome quality of life modification. Avoiding potholes, speed humps and steep driveways is no longer a concern.
1974 TA22 Celica
2013 86 GT
Old 06-28-2021, 12:01 AM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Turdinator: but i'm slightly curious now how car behaves NOT offroad . How comfortable/not TRD rally suspension is on public roads (if compared to stock, as well known baseline), and .. how it feels, if one were to take such lifted one to track
Old 06-28-2021, 12:03 AM   #28
abec
I was up in Washington for some Dirtfish, and while exploring some back roads, this happened!
https://www.instagram.com/p/CIzIU8SH..._web_copy_link
Had I been even on stock springs, this would have been REALLY BAD. However all that happened was it knocked my bumper halfway off and I had to replace some clips and the corners lights.
Just 10mm of lift goes a long way in increasing quality of life with these cars on some horrible back roads. After this I seriously considered some of those lift spacers, lol.
dirt, drift, rally, suspension, trd
TRD Rally Suspension FeRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 01-22-2020 03:29 PM
RALLY SUSPENSION / LIFT / OFF ROAD NYCsubaruBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 08-30-2017 07:09 PM
Wheel and tire specs for FRS (New Tein Flex Z suspension installed) c0nnexi0n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-18-2017 08:58 PM
stock FRS suspension F+R with H&R sport springs installed Corradooo Brakes, Suspension, Chassis 6 06-11-2015 09:51 PM
Robispec Suspension Installed: A Review sw20kosh Tracking / Autocross / HPDE / Drifting 57 08-17-2013 02:12 PM
