Old 11-23-2013, 04:01 AM   #1
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
RALLY SUSPENSION / LIFT / OFF ROAD
Is there any way to lift the brz up an inch? or maybe a rally/off road coil over kit? what is the best suspension set up for potholes, dirt roads, bumps, dips, catching air, etc....
where can i find this?
NYCsubaruBRZ is offline   Reply With Quote
Old 11-23-2013, 04:22 AM   #2
diss7
Drives: AE86, 2x GT86, TE27
Cusco make a rally set that does what youre after.
diss7 is offline   Reply With Quote
Old 11-23-2013, 05:24 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The Nameless rally car is running MCA suspension.
Old 11-23-2013, 06:55 AM   #4
coyote
coyote's Avatar
Drives: Slowly
Spend 5k on some MCA Golds and you're set.
Sent from my Nexus 4 using Tapatalk
coyote is offline   Reply With Quote
Old 02-06-2014, 09:50 AM   #5
NYCsubaruBRZ
http://www.ft86club.com/forums/showthread.php?t=57564
Old 02-06-2014, 10:00 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
with that avatar, i can't take anything you post seriously
Old 02-06-2014, 10:30 AM   #7
mrk1
Drives: Sterling BRZ Ltd
Subtle Solutions has strut spacers. I ran King Springs on my STI, gave about 1.5" of lift, it was a blast.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-30-2017, 12:24 AM   #8
four-mat
Drives: 2014 Subaru BRZ
Is a bagged super high but stiff an option or am I just stupid?
Sent from my LG-H918 using Tapatalk
four-mat is offline   Reply With Quote
Old 08-30-2017, 10:27 AM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Don't do that.
Take a look at the Flatout coilovers if you wanna go up.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-30-2017, 10:37 AM   #10
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
A recent option and thread...
http://www.ft86club.com/forums/showthread.php?t=116377
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 08-30-2017, 02:51 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Good luck with the first rock you hit that pops the bags...
Old 08-30-2017, 04:05 PM   #12
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
I did this diy in my mazda 3 by just blowing all 4 struts. Good times.
Slammillionaire is offline   Reply With Quote
Old 08-30-2017, 04:09 PM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
Here I was thinking that the standard OEM suspension setup was default 'rally' spec, gravel road!
Old 08-30-2017, 06:09 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
Highly doubt it. This is no wrx/sti/evo, where rally use might be way more common. Too little suspension droop travel, too little ground clearance. Main target for suspension setup most probably tarmac tracks, not road-hole ridden bad roads and high jumps.
DIY: Air Lift Suspension Install RallySport Direct DIY (Do-It-Yourself) Guides 63 04-16-2016 11:42 PM
Air Lift Performance Air Suspension In Stock at RallySportDirect.com!! RallySport Direct Brakes, Suspension, Chassis 14 06-03-2014 11:11 AM
Road Rally!! Possible BRZ/FRS meet in Las Vegas?!? ESC POD Southwest 9 01-04-2013 01:51 AM
Northwest Road Rally GreenLight America CANADA 0 11-02-2012 03:52 PM
Road Rally!! Possible BRZ/FRS meet in Las Vegas?!? ESC POD Southern California 8 10-28-2012 03:01 PM
