Old 12-13-2017, 06:01 PM   #1
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
TRD Rally Suspension
Has anyone tested these yet?
http://www.trdparts.jp/release/2014_...uspension.html
Read a bit on them, they're taller but softer too.
Also cheap as hell:
http://www.nigel-jdmparts.com/index....roduct_id=1204
<-- why is this an emote
FeRS is offline   Reply With Quote
Old 12-13-2017, 06:27 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Click.
Old 12-13-2017, 06:42 PM   #3
FeRS
bruh
FeRS's Avatar
Originally Posted by churchx View Post
Yeah I saw that one, but no one really said anything about how it handled
Mostly just about the pricing and how expensive MCA Golds are
Old 12-13-2017, 10:18 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
I've yet to find out someone english speaking who had them and reviewed.
Maybe there were some reviews in japanese, but my google fu is too weak to find such.
Only thing from distantly similar things for twins that actually got tested & reviewed, were chuhatsu plus lift springs for stock shocks. As for these - nothing. After all, most twins owners target tarmac/track racing, and those few that are seriously into rally, usually are on much higher class rally suspension, that costs 5times more then these. And those in-between usually drive different cars, eg. wrx
Old 12-21-2017, 06:38 PM   #5
Racecomp Engineering
If there's real interest, we would consider making a "fun" rally spring (i.e not a WRC caliber set-up). I'm hesitant, but I do think it would be extremely awesome.
RCE Rally springs
Bilstein B6
Braid or Enkei or Method wheels
Subaru/FHI 4 pot 2 pot brakes
big ol' mudflaps
This but a BRZ:
I have been thinking about this quite a bit...
- Andrew
Old 12-21-2017, 09:27 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Andrew: btw, what travel compared to stock B6 have? Aren't KW coilovers with more travel? As for real demand .. i doubt a bit in potential customers for low end "fun-rally" suspension gathering in large enough numbers to warrant developing of custom revalved struts for rally use. Those with really low budget probably will use low cost beaters, not yet as relatively new/costly car, those for just slight gravel/ice fun already may get something like chuhatsu lift springs or Paranoid Fabrications/Subtle Solutions/ADF lift spacers, these TRD rally coilovers or max travel feal 441, those that are really into serious rallying, will use 7-10K custom kits made by some rally suspension builder or by some well known vendors like Ohlins/Rieger or whatever that was fit in Nameless or Cusco rally twins and so on .. or maybe those serious rallying teams will get CS-V3 rally twin from get go
Rally still is sport i like watching most from all the motorsport kinds, but i don't thing there is business case for such kit. Too narrow niche for that
Old 12-22-2017, 05:11 PM   #7
B6 is roughly same travel as stock. KW have more bump travel but aren't designed to be raised.
Custom valved struts would raise the cost considerably and I don't think the demand would be there to do larger production runs. The standard Bilstein B6 valving would fine IMO, plus the bonus that they are inverted monotube fronts.
That's always been the tough part for rally type suspensions for Subarus. Anyone that's going to seriously compete will spend the big bucks (as they should) but there's very little in what would be the equivalent of a simple track day set-up.
Same. Still the most exciting motorsport to me.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
wparsons (12-22-2017)
Old 12-22-2017, 06:25 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Andrew: if just lift is wished and travel of B6 is same .. these lift spacers seemed interesting product, as ones that may add also extra 1.5deg camber. Unfortunately that's alternative only to rather high stack height only, less thick then 1.5" spacers were of pass-through only type, not offset. ADF also offers trailing arm spacers.
Old 12-23-2017, 05:10 AM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I'd love a suspension that lifts it a tad and yet still has better handling than stock. If i had the money I would try this trd suspension, including shipping it is under $1000.
Old 12-23-2017, 02:41 PM   #10
Yeah but no extra travel with strut spacers.
- Andrew
Old 12-23-2017, 05:21 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, but isn't it strut construction, that limits droop travel (of course if magic zip ties aren't used to limit droop )? Am i wrong thinking that longer/bit more firm springs just move neutral point below that of with stock spring? Will in that case longer springs change full droop travel at all or just add some ground clearance lift in same way as lift spacers do?
Old 12-24-2017, 02:25 PM   #12
If a spring raises the front 15mm, it adds 15 mm of bump travel and therefore subtracts 15 mm of droop travel. (assuming OEM style strut).
A strut spacer would just add ground clearance with no effect on travel.
- Andrew
Old 02-24-2018, 04:44 PM   #13
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
RCE Rally springs
Bilstein B6
big ol' mudflaps
This but a BRZ:
- Andrew
Are y'all still considering this? I need a rally suspension for these garbage Hawaii roads ...and maybe to do some rally cross
Sent from my Pixel XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 03-09-2019, 03:35 AM   #14
abec
Drives: 2019 Series Grey, 2016 FRS RIP
I have these on order from BlackhawkJapan, will be a few months before they arrive as they have to come by sea. I will make a thread once they come in.
The information I can gather is that these are for a spec series in japan called the TRD Rally Challenge, now known as the Gazoo Racing Rally Challenge
The race series itself is primarily tarmac with some light gravel/dirt.
abec is offline   Reply With Quote
frs, rally, trd
Rally GT86 - The Little Car That Could - Lots of rally video and photos! Circuit Motorsports Tracking / Autocross / HPDE / Drifting 48 10-12-2020 03:32 PM
RALLY SUSPENSION / LIFT / OFF ROAD NYCsubaruBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 08-30-2017 06:09 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
