Old 06-21-2019, 04:48 PM   #1
TOtS
Drives: 2018 BRZ tS
How long to wait after installing headers to flash OFT stage 2?
Hi
I'm installing carless UEL headers on my BRZ now.
I had OFT Stage 1 flashed for about a week.
Can I flash Stage 2+ tune right after installing the headers or should I wait a bit?
TOtS is offline   Reply With Quote
Old 06-21-2019, 05:51 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You can, and should, flash immediately.
BigTuna is offline   Reply With Quote
Old 06-21-2019, 06:13 PM   #3
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 06-21-2019, 06:57 PM   #4
Jpembry
Drives: 2019 Subaru BRZ Series.Gray
Yea, I flashed mine immediately after install before I ever even started the car
Jpembry is offline   Reply With Quote
Old 06-22-2019, 12:58 AM   #5
kev0
Drives: '14
Don't forget to retorque screws after a few heat cycles.
kev0 is offline   Reply With Quote
Old 06-22-2019, 01:39 AM   #6
86MLR
86MLR's Avatar
I had mine tuned 5000km after going full decat exhaust.
Not tuning your NA car will not be a issue, without a tune a header and full exhaust is worth maybe 5kw up top, maybe, with a good tune there is another 30kw available.
Old 06-22-2019, 01:45 AM   #7
86MLR
86MLR's Avatar
Depends on what gaskets you use really.
I've never re-torqued, I only use quality steel gaskets on a head though.
I've never had an exhaust leak.
Old 06-22-2019, 12:21 PM   #8
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
You could even flash right before you install the headers.
Old 06-22-2019, 03:34 PM   #9
Bluefire98
Drives: 2015 Scion FRS
Flash er up. After you flash, be sure to let it idle for a couple minutes. Then drive around for 10-20 miles under 4kish for a bit. Avoid wot and just let the ecu relearn all the parameters before you go do some hard driving. You should feel the car slowly get smoother after a bit. And yes, definitely go back to make sure everything is torqued correctly. A friend helped me with mine and when I went to go re-tighten everything, the bolts he did were pretty loose lol. Like cmon. Friends don't let friends have exhuast leaks.
Bluefire98 is offline   Reply With Quote
Old 06-22-2019, 03:47 PM   #10
TOtS
Drives: 2018 BRZ tS
I kept my OEM gaskets on the car. They only had 15,000km on them and looked mint.
Old 06-22-2019, 03:49 PM   #11
TOtS
Drives: 2018 BRZ tS
How can I tell if/when I have a leak?
Old 06-22-2019, 11:36 PM   #12
Bluefire98
Usually by sound. Sometimes you can smell one considering it's before the 2nd cat.
Old 06-30-2019, 08:36 AM   #13
TOtS
Drives: 2018 BRZ tS
It does smell bad, I can't keep the car on and stand outside anymore. It also sounds different. But I'm not sure what's normal and what's not AFAIK cat less headers do smell more and sound different.
I'll take it back to the shop to get it checked just to be sure.
Old 07-01-2019, 03:03 PM   #14
CSPTK
Drives: 2014 FR-S
Easiest way is to check all connections right after a cold startup on a cold morning. Look for steam/leak at manifolds and all exhaust seams. Leave it on jackstands overnight so you can scoot under car right after you start it. You can even feel (obviously dont touch, more of get your hands close to the joints) the seams with your hands for a couple minutes before it gets too hot.
Stay clear of belts/pulleys/fan.
CSPTK is offline   Reply With Quote
I bought Tomei Headers and have OFT. Do I just flash the Stage 2 Tune? GT86 Guy Software Tuning 3 08-06-2016 06:44 PM
Just flashed OFT Stage 2 UEL E85 tune. How long should I wait before logging? momo3605 Software Tuning 7 02-21-2015 07:32 AM
How long did you wait for your FR-S? polarbear Scion FR-S / Toyota 86 GT86 General Forum 192 08-21-2012 09:17 PM
After a Long wait, My FR-S is here!! R2RO Scion FR-S / Toyota 86 GT86 General Forum 50 07-31-2012 03:16 PM
How long should i wait ? adprokid Scion FR-S / Toyota 86 GT86 General Forum 7 06-23-2012 01:30 AM
