| Software Tuning Discuss all software tuning topics. |
Drives: 2018 BRZ tS
How long to wait after installing headers to flash OFT stage 2?
Hi
I'm installing carless UEL headers on my BRZ now. I had OFT Stage 1 flashed for about a week. Can I flash Stage 2+ tune right after installing the headers or should I wait a bit? |
#2 |
Drives: 2013 WRB BRZ
You can, and should, flash immediately.
| The Following User Says Thank You to BigTuna For This Useful Post: | TOtS (06-21-2019) |
#3 |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
| The Following User Says Thank You to Westen86 For This Useful Post: | TOtS (06-22-2019) |
#4 |
Drives: 2019 Subaru BRZ Series.Gray
Yea, I flashed mine immediately after install before I ever even started the car
| The Following User Says Thank You to Jpembry For This Useful Post: | TOtS (06-22-2019) |
#5 |
Drives: '14
Don't forget to retorque screws after a few heat cycles.
#6 |
I had mine tuned 5000km after going full decat exhaust.
Not tuning your NA car will not be a issue, without a tune a header and full exhaust is worth maybe 5kw up top, maybe, with a good tune there is another 30kw available.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#7 |
Depends on what gaskets you use really.
I've never re-torqued, I only use quality steel gaskets on a head though. I've never had an exhaust leak.
| The Following User Says Thank You to 86MLR For This Useful Post: | MX-5RACER (06-22-2019) |
#8 |
#9 |
Drives: 2015 Scion FRS
Flash er up. After you flash, be sure to let it idle for a couple minutes. Then drive around for 10-20 miles under 4kish for a bit. Avoid wot and just let the ecu relearn all the parameters before you go do some hard driving. You should feel the car slowly get smoother after a bit. And yes, definitely go back to make sure everything is torqued correctly. A friend helped me with mine and when I went to go re-tighten everything, the bolts he did were pretty loose lol. Like cmon. Friends don't let friends have exhuast leaks.
#10 | |
Drives: 2018 BRZ tS
I kept my OEM gaskets on the car. They only had 15,000km on them and looked mint. |
#11 | |
Drives: 2018 BRZ tS
#13 | |
Drives: 2018 BRZ tS
AFAIK cat less headers do smell more and sound different.I'll take it back to the shop to get it checked just to be sure. |
#14 |
Drives: 2014 FR-S
Easiest way is to check all connections right after a cold startup on a cold morning. Look for steam/leak at manifolds and all exhaust seams. Leave it on jackstands overnight so you can scoot under car right after you start it. You can even feel (obviously dont touch, more of get your hands close to the joints) the seams with your hands for a couple minutes before it gets too hot. Stay clear of belts/pulleys/fan. |
| The Following User Says Thank You to CSPTK For This Useful Post: | TOtS (07-01-2019) |
| I bought Tomei Headers and have OFT. Do I just flash the Stage 2 Tune? | GT86 Guy | Software Tuning | 3 | 08-06-2016 06:44 PM |
| Just flashed OFT Stage 2 UEL E85 tune. How long should I wait before logging? | momo3605 | Software Tuning | 7 | 02-21-2015 07:32 AM |
| How long did you wait for your FR-S? | polarbear | Scion FR-S / Toyota 86 GT86 General Forum | 192 | 08-21-2012 09:17 PM |
| After a Long wait, My FR-S is here!! | R2RO | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 07-31-2012 03:16 PM |
| How long should i wait ? | adprokid | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 06-23-2012 01:30 AM |
