Old 05-28-2019, 06:03 AM   #1
jjoconnor
jjoconnor's Avatar
Drives: 2014 Subaru BRZ
Loud Valve Tapping After Driving Hard
Hello Members,
I've noticed that recently, after doing a mountain run (Redline, windy roads) that at idle, the valve tapping is horrendously loud even from inside the cabin. Oil is 100% full and checked (0w-20) and the tapping is noticeable for about 30 seconds after coming to idle.
I know that valve tap is noticeable on these engines but I'm speculating that there are some oil flow issues to the heads, anyone had similar issues on track etc?
Thanks,
Jeth
jjoconnor is offline   Reply With Quote
Old 05-28-2019, 07:54 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Are you sure you aren't hearing the DI or the AVCS? Both systems make a tapping noise. I think there is another thread with a video of the engine where someone had the same question.
The Following User Says Thank You to Spuds For This Useful Post:
nikitopo (05-28-2019)
Old 05-30-2019, 12:48 AM   #3
kt45
Drives: BRZ 2013 MT
If it increases with rpms and it makes noise at idle, pop the hood and listen. If you can tell which side its coming from, left or right, then its valve noise. If you cant it could be rod knock.
From my experience I had both happen at the same time.
kt45 is offline   Reply With Quote
0w-20, engine, oil, oil pressure, valves
Loud Clunk while driving Flame9020 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-23-2018 10:28 PM
Tapping Noise After Hard Driving (Video Included) Deisou Issues | Warranty | Recalls / TSB 6 08-06-2017 07:27 PM
Tapping noise after driving MrAnthonyC Issues | Warranty | Recalls / TSB 2 09-23-2014 02:06 PM
clicking/tapping noise when shifting semi hard Skurge Issues | Warranty | Recalls / TSB 3 09-20-2013 05:37 PM
diy request: install a driving camera by tapping power from the interior map light. shaoster DIY (Do-It-Yourself) Guides 6 01-24-2013 03:02 PM
