Old 05-08-2019, 03:43 PM   #1
YgRoshi
YgRoshi's Avatar
Drives: 2017 86 MT BASE
Rattling noise from exhaust?
Just recently changed out my over pipe and front pipe. I already have in India header and Invidia exhaust in the car and it was completely fine just not loud enough haha. The over pipe and front pipe I put in are also both invidia, and the front pipe is cat-less. It’s been making this rattling noise for a few days now and I just got it checked at a shop and they found a leak but the sound is still there so the mechanic told me that it could be because it is cat-less and is causing detonation which sounds similar to an exhaust leak? I was wondering if there could be anything done to prevent the noise? Or should I just get a catted front pipe?
YgRoshi is offline   Reply With Quote
Old 05-08-2019, 05:29 PM   #2
Vital
Drives: 2015 BRZ
Well, if you're fully catless there could definitely be some rasp. I would check the clearance from the header to overpipe or just check under there for any loose bolts. It is possible your overpipe might be hitting the heat-shield.
Old 05-08-2019, 07:16 PM   #3
YgRoshi
YgRoshi's Avatar
I see, will getting a catted front pipe fix the rasp?
Old 05-08-2019, 07:35 PM   #4
86MLR
86MLR's Avatar
For the rasp I would just get a small resonator cut/welded in the front pipe, and, if the mid pipe doesn't have one, get a resonator in there too.
Resonators will not restrict flow, they will just cut down the tone not the volume.
As for the rattle, I would say it isn't installed correctly, maybe missing a hanger?
Put the car on stands and give it a good shake.
Hopefully it's not bad bends at the overpipe, that would suck.
Old 05-09-2019, 02:59 AM   #5
YgRoshi
YgRoshi's Avatar
Great! Thanks!
Old 05-09-2019, 04:11 AM   #6
jflogerzi
jflogerzi's Avatar
Just put stock FP back in if you still have.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Tcoat (05-09-2019)
Rattling noise coming from car? YgRoshi Scion FR-S / Toyota 86 GT86 General Forum 8 04-22-2019 07:32 PM
Rattling noise on a stock BRZ? merdok12 Engine, Exhaust, Transmission 22 10-25-2016 06:58 PM
Rattling noise Eighty 6 Scion FR-S / Toyota 86 GT86 General Forum 4 06-07-2016 12:54 PM
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 01:34 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-27-2012 12:19 AM
