| Engine Swaps Discussion of engine swaps. |
#43 |
Drives: Toyota
Do you sell a kit for this? I'd be interested.
#44 |
Drives: 2016 FRS
Not yet, still perfecting the canbus setup for 100%. Also the Toyota security is a problem. I have not had any issues with it but recently the immobilizer went bad and replacing the immobilizer wont work for me since I don't have techstream. I was trying to avoid doing full stand alone just to keep cost down but now I have to. Once I have everything dialed in to where anyone can do the swap I will release a kit.
#45 | |
2013 Series 10 FRS #553
#46 |
Drives: 2016 FRS
#47 |
Drives: 2018 BRZ Limited Perf Pack
Yo....
So, I have the privilege of living near this build and getting to see it in person regularly. If it weren't for the big hole in the hood, you'd never know it wasn't stock. The work is that nice and the planning really paid off. I got involved when srscion had a fueling issue that was traced back to the fuel filter clogging. The cars use a polyethylene terephthalate (PET) mat fuel filter. srscion gave me the filter to examine (I'm a chemist with access to a nice analytical lab) in hopes of finding out what was plugging it up. I examined the exterior of the filter, which smelled of fuel, and found no unusual materials. Typically, one finds sand, calcium, and other mineral deposits. None here. I opened the filter, expecting to find smaller particle size materials, and yeah, nothing. I was able to identify the material by infrared scanning, and from there contacted some manufacturers of PET materials for fuel filters. They advised that they have seen this before and it is related to fuel contamination, specifically in E85, and small gels form on the fuel filter surfaces (very tiny!) which block flow. The major challenge is that these materials all evaporate once the filter is exposed to air, so it is nearly impossible to track down the actual cause. Without bagging the filter and running it to the lab immediately, the likelihood of finding the actual materials that gelled up is not happening. Typically, when there is residue on a base material, the baseline of the scan will be awful. This is much closer than I expected, confirming what my PET peeps said. So, this was a disappointing analysis because it did not have a result other than someone sold some crappy fuel.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
| The Following 4 Users Say Thank You to atomicalex For This Useful Post: |
#48 |
Drives: 2016 FRS
Swap Kit
Looking to release a kit 4th quarter 2019, stay tuned...
| The Following 2 Users Say Thank You to srscion For This Useful Post: | atomicalex (09-30-2019), Dadhawk (07-03-2019) |
#49 |
Drives: 2013 Firestorm FR-S
Very excited about this.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#50 |
Drives: 2016 FRS
Just wanted to touch base, I have been busy working some further refinements out as well as the final design on the hood adaptation for this swap. I had to push things back a bit but its still on track for release. Thanks for your patience.
| The Following User Says Thank You to srscion For This Useful Post: | Evil Rocky (03-10-2020) |
#51 |
Drives: 2015 frs
Nice! Did you finalize the method, material, and builder to get the hood done?
#53 |
Drives: 2016 FRS
All done!!
All finished, I will be working on shooting video next.
| The Following User Says Thank You to srscion For This Useful Post: | Zer0 (06-20-2020) |
#55 |
Drives: 18 Brz (Sold) / 22 BRZ
Nice build.
| Toyota Aristo Engine Harness Conversion to USDM Supra TT to Swap into FRS | ThePurist | Engine Swaps | 0 | 11-23-2017 09:13 PM |
| Toyota left a nice surprise if you're doing a Toyota motor swap.. | Manji | Engine Swaps | 15 | 01-07-2015 02:48 AM |
| Engine swap JDM EJ25 STI engine | FRSToyota86 | Engine Swaps | 25 | 11-20-2013 02:56 AM |
| Engine Swap | hybrid35 | Southern California | 0 | 01-07-2013 02:04 PM |
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
