Old 04-25-2019, 11:23 AM   #1135
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Engine is somewhat Ready to go back in. I hope to have it installed tonight, running by tomorrow night.
Crank Pulley was a nightmare. 2 different installer kits and neither worked. Autozone ended up having the "Long Reach Harmonic Balancer Install kit" that worked. Though I had to come up with a spacer to be able to reach the nut for tightening it. Almost slid on by hand turning the nut, which I think means I didn't mess up the woodruff key.
I went ahead and marked each bolt after checking each torque, also to make sure they don't move:
Clutch installed. Bolts I have weren't exactly the same as before. Seems the Thread pitch and length are the same, but the width of the head is not. I don't think it will cause an issue, and the clutch was balanced using these bolts. I can change them out in the car need be.
Trans is on, just need front accessories
Old 04-25-2019, 12:02 PM   #1136
toast
Drives: 14 BSP Edelbrock BRZ
It's amazing how fast you can get when you do something repeatedly. My first clutch install took about 7 hours with an ACT that I hated so 2 weeks later I did it again, added a bunch of other tasks to the work and still finished in less than 3.
You're going to be like a NASCAR pit crew soon.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
DustinS (04-25-2019)
Old 04-25-2019, 12:10 PM   #1137
DustinS
DustinS's Avatar
I probably could have had the engine/trans in the car had I not had to run all over town trying to find a stupid pulley installer that would work.
Old 04-25-2019, 10:08 PM   #1138
Zer0
Drives: 2015 frs
What kind of installer did you use? The one I bought was a piece of allthread, and a couple of washers with a nut. It worked pretty well.
Zer0 is offline   Reply With Quote
Old 04-26-2019, 10:20 AM   #1139
DustinS
DustinS's Avatar
Pretty much that. This one has a bearing on it to help it turn a little easier:
Engine was installed last night.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
zeal86 (04-29-2019), Zer0 (04-26-2019)
Old 04-26-2019, 10:55 AM   #1140
Zer0
Drives: 2015 frs
That kit is way nicer than what I used. I did buy a bearing to place under the nut to make it easier to turn. They wanted you to use 2 washers with grease in-between them.
Old 04-29-2019, 10:27 AM   #1141
DustinS
DustinS's Avatar
Started off the weekend making new radiator mounts as the ATI crank pulley sits out further than my old one and the radiator didn't fit with the engine in the car.
They still need finalized and cleaned up, but I like them so far. Glad I had to redo them, the welds were garbage with little to no penetration. Need to set it up better for the thicker material.
Moved on to new steam lines
Old ones were pretty shot:
Finalized placement of the oil filter relocation. That sucked to install with the engine in the car, but I made it work. I installed rivnuts to make removing it a lot easier. The tool fit just enough to get them seated.
Lines routed out of the way of the heat from the manifolds.
Made an adapter for the factory oil temp sensor so I can use the one in my cluster.
I really need to change the steam port setup. They suck to install and it looks like a mess. I'm also afraid it's going to leak really bad.
Engine is almost all wired/plummed up. Just waiting on the 45 degree -20an fittings.
The Following 4 Users Say Thank You to DustinS For This Useful Post:
Axis2011KR (04-29-2019), gtpvette (04-29-2019), zeal86 (04-29-2019), Zer0 (04-29-2019)
Old 05-01-2019, 03:06 PM   #1142
DustinS
DustinS's Avatar
Hopefully these turn out how I want. 18hr print a piece, I have to print them in 4 parts to fit on my printer (sounds like I needed the bigger printer haha!).
The Following User Says Thank You to DustinS For This Useful Post:
zeal86 (05-02-2019)
Old 05-02-2019, 04:50 AM   #1143
Zer0
Drives: 2015 frs
What are they for?
Old 05-02-2019, 10:32 AM   #1144
DustinS
DustinS's Avatar
What are they for?
Radiator Fan Ducting:
They will need clearanced for the radiator lines, but easy enough to do. As long as it help direct the air up into the hood vents.
Sportsguy83 (05-02-2019), zeal86 (05-02-2019)
Old 05-02-2019, 10:41 AM   #1145
zeal86
zeal86's Avatar
Drives:
Posts like these are going to make me buy a 3D printer. I love that you design and fabricate your own parts.
Yours is one of the few builds I follow... lots of embedded knowledge and experience in your posts.
IG @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
DustinS (05-02-2019)
Old 05-02-2019, 10:59 AM   #1146
Zer0
Drives: 2015 frs
That's what they looked like. Damn how big is your 3D printer? The size they would be threw me off. I thought it was ducting for the radiator but didn't think you could do them even in 4 parts at home.
Old 05-02-2019, 11:26 AM   #1147
DustinS
DustinS's Avatar
IG @zeal.eightsix
Thank You I really appreciate that.
11.8" x 11.8" x 15.7" (300mm x 300mm x 400mm). The Duct is 12" in diameter, so they just barely don't fit. They have two other printers larger than mine. The Creality CR-10 s4 and s5. S4 has a 400mm x 400mm x 400mm build plate, which would be the ~15.7" and the S5 has 500mm build volume. A huge 19.6" in each direction. I will eventually get one of the other as well, but for now it works.
Sportsguy83 (05-02-2019), Zer0 (05-02-2019)
Old 05-02-2019, 11:30 AM   #1148
zeal86
zeal86's Avatar
Drives:
So do you design your printed parts in a program or do you 3D scan them? Or both?
IG @zeal.eightsix
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
