Old 04-23-2019, 08:25 PM   #1
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Flexing Throttle Pedal
Not sure if this is the right subforum, but is there a fix for the throttle pedal's side to side play? I can feel the pedal move from side to side and when I had a pedal spacer, the pedal would move/slip to the side of the raised pedal stopper. I've placed grip tape on the pedal stopper and the back side of the throttle pedal. Didn't help much.
iLuveKetchup is offline   Reply With Quote
Old 04-23-2019, 08:48 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Welcome to sports cars on a budget It's normal. Shouldn't be, but it is. Buy a BMW - bottom mounted pedals don't do this.
Old 04-23-2019, 09:06 PM   #3
iLuveKetchup
Drives: EFF JAY
I know it's normal but I'm surprise there isn't a fix or more of an issue. Here's a video clip of my last autox which highlights the problem. I've since removed the pedal spacer.
[ame]https://www.youtube.com/watch?v=j9wmWun_7mM[/ame]
Old 04-23-2019, 09:11 PM   #4
That doesn't look normal to me. 0_o
Pull that sucker out and inspect it. Two screws and a connector.
humfrz (04-23-2019)
Old 04-23-2019, 09:28 PM   #5
Well, the pedal on my 2013 FR-S sure doesn't do that -
I agree, something is wrong with the pedal on your car.
Old 04-24-2019, 08:51 AM   #6
iLuveKetchup
Drives: EFF JAY
Do you guys have a pedal spacer? The issue is only apparent when you use a taller pedal stopper (to be used with the spacer). There is a notch on the bottom-back of your OEM pedal, with the the side-to-side play inherent with the twins, that notch (and pedal) can slip off the taller stopper. With the OEM stopper, since it is more of a flat surface, the pedal has no where to fall to and you don't really notice.
taller pedal stopper...
OEM pedal stopper...
Taller pedal stopper installed. You can see the notch on the bottom of the pedal. On the video the car is loaded on the left, and with the throttle pinned, the pedal has enough play that the notch/pedal slips to the left of the stopper.
Old 04-24-2019, 09:02 AM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
That was kinda scary. Almost moved enough to get caught behind the brake pedal.
I wonder if @VerusEric has any insight.
BigTuna is offline   Reply With Quote
Old 04-24-2019, 09:19 AM   #8
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We have not noted this on either of our shop cars (FRS/BRZ or WRX) and none of our customers have noted this issue either.
I went out to my car and hooked up a load gauge to see how much lateral load it would take to move the pedal roughly this much (guessing from the video posted above). It requires roughly 25 lbs laterally... the way I personally drive I do not believe I push on the pedal laterally more than a few pounds. The movement is in the throttle pedal assembly itself... I don't see how there is much that can be done to strengthen this as the movement appears to be internal but I will review it a bit more later today.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
churchx (04-24-2019), iLuveKetchup (04-24-2019), norcalpb (04-24-2019), Tcoat (04-24-2019)
Old 04-24-2019, 09:27 AM   #9
BigTuna
BigTuna's Avatar
Thanks,
Eric
That's some fast data acquisition!
Old 04-24-2019, 09:35 AM   #10
iLuveKetchup
Drives: EFF JAY
Thanks @VerusEric!
Old 04-24-2019, 04:09 PM   #11
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Wow, I think there is something wrong with your pedal.
I have the Verus pedal spacer, and the pedal never slip out of the pedal stopper.
There is some side to side play (not caused by the verus spacer). Probably because the pedal assembly is made of plastic. But you seem to have a lot more play than me.
nico_rsx is offline   Reply With Quote
Old 04-24-2019, 04:47 PM   #12
iLuveKetchup
Drives: EFF JAY
There are factors in play.. Do you have your spacer set so the pedal is closest to the brake pedal? Are you racing in an autocross or track environment where you are full throttle at corner exit? I really doubt that anyone will notice any movement on the street, IMO.
I'll buy a new pedal assembly and test. I don't think my pedals are any different or worse, but I'm going to check other FRS/BRZ pedals in my region.
If this is the complete set up with assembly, it's cheap enough just to test.
Old 04-24-2019, 05:43 PM   #13
norcalpb
norcalpb's Avatar
Take apart the assembly before buying a new one. There’s a little white tap that “locks” the pedal in the correct orientation. Try to see if that’s not destroyed.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 04-24-2019, 09:33 PM   #14
nico_rsx
Yes I autocross and some HDPE. But I don't have the spacer set to the closest to the brake. That won't increase the play in itself, but I can see how that may put the pedal to the edge of the stopper, and so easier to slide off.
But I watched your video, and my pedal doesn't move as much, but there is some play. Maybe with age (and aggressive pedal input), the assembly slowly wear and the play increase (my car is only 2 years old).
** SOLD ** Velox / Verus Throttle Pedal Spacer Kit $85 chickunfut Interior Parts (Incl. Lighting) 3 12-09-2018 09:43 PM
Gas Pedal to Throttle Input Delay JDMPR725 Electronics | Audio | NAV | Infotainment 1 10-10-2017 04:46 AM
Throttle Pedal Sensitivity Nah Software Tuning 8 12-05-2016 02:35 PM
Sloppy throttle pedal allowe Engine, Exhaust, Transmission 23 11-02-2016 03:11 PM
Throttle Pedal Lag gonzo Software Tuning 4 08-29-2014 03:07 AM
