Old 03-24-2019, 10:47 AM   #1
stlgrym3
Do I need to add more coolant?
Noticed my coolant level is at midway between max and min. Should I add more? If so, what type of coolant go get?
stlgrym3 is offline   Reply With Quote
Old 03-24-2019, 11:26 AM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Nope. That's right where it should be.
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (03-24-2019), stlgrym3 (03-24-2019)
Old 03-24-2019, 03:38 PM   #3
Yep, if your engine was cold at that level, don't mess with it.
It's an expansion tank (see manual).
If you ever have to add coolant use only the Subaru Blue stuff. Or deionized or distilled water if it just is down a little.
Old 03-24-2019, 06:15 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
The proper coolant is either the ready mix blue coolant from Toyota, or Subaru's ready mixed coolant.
Here's the deal man,
1. You could buy a gallon of the blue coolant for $40 at the dealership and only use about a cup. Then have it for summer when you'll need to add another half cup.
2. You can buy a gallon of distilled water for $1 and use a cup of it. Then you can have it for the summer when you'll need to add another half cup.
Either way you'll only need about a cup or two to fill up to the line.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (03-24-2019)
Old 03-24-2019, 06:32 PM   #5
Now, Mr.ac, THAT is one of your better posts -
Old 03-24-2019, 07:00 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
You meant to say bubba adds a smidge from the garden hose til he thinks its full, right?
The Following 3 Users Say Thank You to ZionsWrath For This Useful Post:
humfrz (03-24-2019), Ultramaroon (03-24-2019), wparsons (03-29-2019)
Old 03-24-2019, 07:39 PM   #7
Iffen the garden hose ain't hooked up, he just adds a bit of windshield washer fluid -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
wbradley (03-27-2019), wparsons (03-29-2019), ZionsWrath (03-25-2019)
Old 03-24-2019, 07:52 PM   #8
omfg
Old 03-27-2019, 10:48 AM   #9
stlgrym3
the line you were referring to was the "max" line?
Old 03-27-2019, 08:01 PM   #10
Yep, fill to the "max" line if the system is hot. If the system is cold the level should be somewhere mid way between the lines.
Old 03-27-2019, 10:04 PM   #11
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yes. If coolant level is at the middle you'll need like 1 to 1 1/2 cup of fluid. From the low level you'll need about 3 to 3 1/2 cups. Give or take a few.
Simple shit huh?
Old 03-29-2019, 10:37 AM   #12
wparsons
wparsons's Avatar
Quoted for emphasis, don't ever add to the coolant when it's not up to full operating temperature.
flickr
humfrz (03-29-2019)
Old 03-29-2019, 10:42 AM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
And because I've seen it done, please don't add coolant to a hot engine through the radiator cap.
Took nearly 8 months before his face looked good again.
ZionsWrath (03-30-2019)
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
is my coolant low? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-19-2013 11:43 PM
