| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Do I need to add more coolant?
Noticed my coolant level is at midway between max and min. Should I add more? If so, what type of coolant go get?
![]() Sent from my iPhone using Tapatalk |
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Nope. That's right where it should be.
"I gotta rock." -- Charley Brown |
#3 |
Yep, if your engine was cold at that level, don't mess with it.
It's an expansion tank (see manual). If you ever have to add coolant use only the Subaru Blue stuff. Or deionized or distilled water if it just is down a little. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | stlgrym3 (03-24-2019) |
#4 |
[insert cool phrase here]
Drives: BRZ Premium
The proper coolant is either the ready mix blue coolant from Toyota, or Subaru's ready mixed coolant.
Here's the deal man, 1. You could buy a gallon of the blue coolant for $40 at the dealership and only use about a cup. Then have it for summer when you'll need to add another half cup. 2. You can buy a gallon of distilled water for $1 and use a cup of it. Then you can have it for the summer when you'll need to add another half cup. Either way you'll only need about a cup or two to fill up to the line.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (03-24-2019) |
#5 | |
![]() humfrz |
#6 |
Thanks
You meant to say bubba adds a smidge from the garden hose til he thinks its full, right?
| The Following 3 Users Say Thank You to ZionsWrath For This Useful Post: |
#7 |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#8 |
omfg
| The Following User Says Thank You to Ultramaroon For This Useful Post: | ZionsWrath (03-25-2019) |
#9 | |
#10 |
#11 |
Drives: BRZ Premium
Yes. If coolant level is at the middle you'll need like 1 to 1 1/2 cup of fluid. From the low level you'll need about 3 to 3 1/2 cups. Give or take a few.
Simple shit huh?
#12 | |
Quoted for emphasis, don't ever add to the coolant when it's not up to full operating temperature.
| The Following User Says Thank You to wparsons For This Useful Post: | humfrz (03-29-2019) |
#13 |
Rust bucket enthusiast
And because I've seen it done, please don't add coolant to a hot engine through the radiator cap.
Took nearly 8 months before his face looked good again. |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | ZionsWrath (03-30-2019) |
| How is it possible to lose coolant, if the coolant system in a car is a closed loop, | ghostzfh | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-12-2020 02:09 AM |
| Coolant level dropping & Dirty coolant | redwine | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 44 | 09-30-2018 09:37 PM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 06:56 PM |
| is my coolant low? | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-20-2013 12:43 AM |
