Drives: 2013 Firestorm Red FRS
Requirements For Lowering
It appears this hasn't been entirely discussed (or at least not in its own thread), but what is needed to maximize reliability when lowering? Going with the Eibach Pro-Kit (1-inch drop all around) and planning on adjustable LCAs, rear toe kit and front camber bolts. I hear lots of people damaging their swaybar end links with coilovers, does this need to be addressed as well? TIA.
#2 |
Front endlinks to match drop.
Lowering can cause issues with the oem links both at the upper and lower joints. This info is in this forum, more searching needed.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#3 |
I think a lot of it depends on how low and what your objective are. I'm on some tein flex z. They seem super low to me. All I have are lcas. Maybe I could do better but I don't run into any issues on the street.
Drive upgrades. Don't buy them.
#4 |
Drives: Bone stock
If your worried about endlinks, get adjustable ones.
Sent from my SM-N960U using Tapatalk Last edited by Joveen; 02-02-2019 at 03:37 PM. |
#5 | |
pessimistic skeptic
But I would replace the shocks and struts together with the springs since your car is 2013. |
#6 |
Country Boy 4 Life
When I installed Prokit springs 65k miles ago, I wished I had also installed a Roll center bumpsteer kit. I now have the whiteline kit. The difference in feel is noticable. A nice "planted" feel. I would suggest it with the parts you have.
I LIKE TIRES! |
#7 |
Famous Potatoes
Drives: '15 ultramarine
I have the same. Zero bumpsteer.
| The Following User Says Thank You to Sapphireho For This Useful Post: | Leonardo (02-02-2019) |
#8 |
Emperor McDuck
Drives: 2019 86 GT; 2018 BMW S1000RR
Eibach pro is the same drop as the trd springs they are a factory option and warrantied even as a dealer installed option. If Toyota doesn't even recommend anything other than an alignment, then its safe to say anything more would be unnecessary and likely a waste of money.
| The Following User Says Thank You to xdavidx For This Useful Post: | Alpha86 (02-03-2019) |
#9 |
Country Boy 4 Life
Who decided a roll center kit was not great to install with drop springs?
I LIKE TIRES! |
#10 |
Drives: 2019 Mazda Miata RF
#11 |
Emperor McDuck
#12 | |
Country Boy 4 Life
Mac strut needs the kit to fix the suspension geometry from lowering. Believe whatever you want though.
I LIKE TIRES! |
#13 | |
Country Boy 4 Life
I LIKE TIRES! |
#14 |
Drives: 2014 Scion FRS (Asphalt)
You could skip the rear toe arms. The stock eccentric toe bolt in the rear should be able to keep you in spec with your mild drop.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post: | Alpha86 (02-09-2019), strat61caster (02-04-2019) |
| Ca. Smog requirements | CPO 76 | BRZ First-Gen (2012+) — General Topics | 18 | 04-11-2018 04:35 PM |
| requirements to run openflash manager | Grip Ronin | Software Tuning | 22 | 03-11-2015 03:58 PM |
| Eibach Sportlines requirements | Hawk77FT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-12-2013 12:02 AM |
| 250 ~ 300 hp - Cost, Requirements, Effects | Froylavin | Engine, Exhaust, Transmission | 14 | 07-19-2012 01:55 AM |
| Minimum requirements... | Blokatos | Scion FR-S / Toyota 86 GT86 General Forum | 528 | 11-15-2011 05:04 PM |
