Southern California SoCal
Old 01-03-2019, 01:44 PM   #71
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by MrDinkleman View Post
So, I went to the dealer today to buy some parts, including the sticker. He told me they can't just sell the sticker, willy-nilly. He said I need to go to the dealer I originally purchased it from with proof of purchase. And THEN they will contact Toyota Corporate who will ship them the sticker...
So, plans B and C:
B. Anyone have one for sale?
C. Can anyone post a hi-rez pic that I can just print and stick on the airbox?
Thanks...
The sticker part number is in the install instructions. I just went to the parts department at my Toyota dealer and ordered it.
MrDinkleman (01-03-2019)
Old 01-03-2019, 03:21 PM   #72
MrDinkleman
Drives: 2016 Oceanic, "base" model
Huh! That's right; I forgot about the part number. I think I'll try online... Thanks.
MrDinkleman is offline   Reply With Quote
Old 01-21-2019, 12:41 PM   #73
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Sorry to revive old thread.
Is this possible to pass?
I have this exhaust installed including midpipe with cat
https://www.ft86club.com/forums/showthread.php?t=34386
hanabie is offline   Reply With Quote
Old 01-21-2019, 12:44 PM   #74
jflogerzi
jflogerzi's Avatar
As long as you still have the stock front pipe, OP, and stock headers you are fine.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
hanabie (01-21-2019)
Old 12-02-2020, 09:38 PM   #75
AbductedCasper
AbductedCasper's Avatar
Drives: FR-S Release Series 2.0 #349
Sorry to bring up this old thread but do you pass on a stock E-85 tune with all stock parts (Exhaust, over pipe, front pipe, mid-pipe, and headers)?
Thanks!
AbductedCasper is offline   Reply With Quote
Old 12-03-2020, 12:51 PM   #76
re-animator
Thanks!
you can't pass on an aftermarket tune at all most likely. "stock" e85 is an aftermarket tune obviously the car doesn't run e85 stock.
re-animator is offline   Reply With Quote
Old 12-03-2020, 06:27 PM   #77
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
The dude earlier in the thread who runs a shop said if all the Readiness Monitors are Ready/complete and the CEL is off, it will pass the scan.
Most of the off the shelf tunes like OFT turn off the CEL. The question is whether the tune allows the readiness monitors to be "complete".
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 12-05-2020, 05:43 PM   #78
jflogerzi
jflogerzi's Avatar
Thanks!
flash back to stock and run 91. Easy to pass. Now if you have Flex Fuel thats a different story
Old 12-09-2020, 12:40 PM   #79
luluma
luluma's Avatar
Drives: 2013 Scion FRS
I have just done the test and passed, the older tech failed the visual test at first and passed after spoke with someone on the phone, the reason was the car branded Scion but all the internal parts are made by Subaru......
luluma is offline   Reply With Quote
The Following User Says Thank You to luluma For This Useful Post:
bcj (12-09-2020)
Old 12-09-2020, 12:59 PM   #80
jflogerzi
jflogerzi's Avatar
Oh God... Thanks for the heads up
bcj (12-09-2020)
Old 01-05-2021, 02:22 AM   #81
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
My OFT screen is busted... I need to get around to fixing the display but I can't think of why I'd fail with a OFT Stage I tune retaining all cats. Guess I'll find out when the time comes...
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-07-2021, 05:20 AM   #82
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Visually assuming stock cats + no modifications to the emission parts, you will pass the visual test. It's the OBD readiness test that you might fail. Not sure if the OFT tune affects the readiness protocols in any way. If it does and it causes certain criteria to show not ready/incomplete, then you will fail.
Bach415 is offline   Reply With Quote
Old 01-20-2021, 05:55 PM   #83
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Not sure how 86 tunes are stored, but if you are in California with a tune and try to pass SMOG be mindful of this:
https://www.bar.ca.gov/pdf/On_Board_...n_10.17.19.pdf
And mainly focus on this:
Calibration Verification Number (CVN): a number set by OEMs to verify the integrity of the vehicle software
Calibration Identification (Cal-ID): an ID for the software installed on the Electronic Control Unit (ECU)
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Decimus (01-21-2021)
Old 03-25-2021, 12:44 PM   #84
jflogerzi
jflogerzi's Avatar
pretty sure the CAL-ID does not change for ecutek or OFT as you are editing the stock ECU... But just flash back to a stock map.
Smog check for out of state people? goshem Southern California 4 09-25-2015 06:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 11:05 AM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-26-2015 11:19 PM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 12:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
