Drives: 2017 Subaru BRZ
So I got this code on my BRZ and I've replaced the OCV with a genuine one from Subaru. I've also done an oil change after the light came on so I know that its not the oil's fault on why this code is popping up. And there's also a knocking noise coming from the same side of the block. I'm pretty sure that they are both related but then again I could be totally wrong. I've also tried to clear the code multiple times but it'll come back on the third time I start it after clearing. I've been stuck on this issue for over a month now. Will I have to rebuild the block or is it still safe? Any info would help.
#2 |
Are you not still in warranty?
#3 |
No it's not
It's a salvage because it was hit from the back.
| WTB: Camshaft Timing Oil Control Valve Assembly Connector | driftking96 | Want-To-Buy Requests | 8 | 05-18-2022 08:02 PM |
| Camshaft timing oil control valve assembly | smellslikecurry | Want-To-Buy Requests | 11 | 04-12-2017 05:36 PM |
| Camshaft timing oil control valve assembly - P0013 | smellslikecurry | Issues | Warranty | Recalls / TSB | 8 | 11-02-2016 10:53 AM |
| Oil Leak at Camshaft Timing Controler | Cal3000 | Issues | Warranty | Recalls / TSB | 17 | 10-03-2015 12:38 PM |
| Camshaft Timing Oil Control Assembly | smellslikecurry | Engine, Exhaust, Transmission | 0 | 12-21-2014 01:10 AM |
