#15 |
Drives: 13 BRZ, 17 Focus RS
I briefly had tires on the rear of the car that were the same make and model, but one had a good bit more tread. The mismatched circumference made the same thing happen to me.
#16 | |
Drives: 17 Toyota 86
#17 | |
#18 |
Drives: 2014 GT86
Better leave out stretch and stance from this, probably more alignment related, thread? "slight" & "nice" differs a bit for ones that care how car handles/performs over arguable looks.
#19 | |
#20 |
#21 |
Hey, the guy set you up for a clockwise circle track. Stand on the gas and up the track you go, take your foot off and dive for the corner. {Although usually done with stagger.}
#22 |
Drives: 2014 Scion FRS (Asphalt)
Maybe something that would be easier next time around would be to get wheels that fit. So your alignment isn't compromised. Not that I'm a big stance person or anything but you don't necessarily need camber for a nice stance.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | Tristor (10-15-2018) |
#23 |
I'm legit trying not to be rude, but if you didn't want to compromise how your car drives you should probably reconsider the path you're headed down. You might try starting at Will this fit? (width, offset, and tire size Qs) to get a different set of wheels and tires that properly fit and then go get a proper street-oriented alignment. If your objective is a stanced out appearance with stretch tires on big wheels, then I guess by all means go for it, but you need to understand your car is going to drive like shit like that. Your issue in this thread can be corrected by backing off from max camber on your plates and getting your toe adjusted out by someone that knows how to do an alignment, but even then on the street you're going to have a rougher time driving. At this point, the stance scene isn't even unique, it just makes you look dumb. |
#24 |
Country Boy 4 Life
What model/brand of 225/40/18 do you have on your 18x9.5 +22 wheels?
Besides BC coils: what other suspension parts do you have installed? I am not a Suspension GURU, but from what I understand the more you lower the car, the more parts are needed to keep it driving ok. Like adjustable endlinks for swaybars, adjustable rear toe arms, adjustable trailing arms etc...
I LIKE TIRES! |
#25 | |
#26 | |
#27 | |
Country Boy 4 Life
I don't know how low you actually are, but I am guessing that you don't have much shock travel left. At this point the OEM suspension is past the point in its height usage range to function properly.
I LIKE TIRES! |
#28 | |
| KW coilovers and camber (without camber plates) | wparsons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 07-09-2018 09:53 PM |
| Uneven rear camber after lowering springs | Euphues | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2015 09:27 PM |
| FS: HVT Non-raising camber plates & WL camber bolts | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-16-2015 10:00 PM |
| 17x9 +42 & 245/40 w/ RCE yellow and maxed camber bolts | jeebus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 09-30-2013 11:25 AM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-28-2013 12:38 AM |
