Old 09-18-2018, 04:38 AM   #15
JIM THEO
Drives: BRZ 2018
Originally Posted by gpvecchi View Post
I re-up this thread because I got my car. Now, I see there’s a masking on the trim piece with the cutout for the camera, but the trunk needs to be drilled.
I can find the horizontal alignment measuring the trim, but I can’t find the vertical measure. Anyone with stock camera may please take it for me?
Plus, is there any groove for the borders of the plate?
Thanks!
Has your car the new Harmann-Kardon infotainment as my MY18 BRZ bought from Italy does or you have other Pioneer etc system?
I contacted more than twice local dealer but they can't find the correct part number for the rearview camera so if we share the same system could you tell me the part number please?
JIM THEO is offline   Reply With Quote
Old 09-18-2018, 05:23 PM   #16
gpvecchi
gpvecchi's Avatar
I live in Italy, but I own an 86. Camera is just for JP and US versions. Not an issue, it can pair with other systems, it just needs 6V for feeding (you can use a 7806 chip). P/N is 86267CA500.
The Following User Says Thank You to gpvecchi For This Useful Post:
JIM THEO (09-18-2018)
Old 09-18-2018, 06:18 PM   #17
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Here is how the factory mounts the reverse camera in my (dirty) Series.Yellow
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 09-19-2018, 01:59 AM   #18
gpvecchi
gpvecchi's Avatar
Could you please measure the distance between the bottom of the trim and the lower edge of the camera plate? Thanks!
Old 09-20-2018, 01:22 AM   #19
dhuang
dhuang's Avatar
~1.1cm from the bottom of the trunk garnish to the edge of the camera plate.
~0.8cm from where the trunk garnish light cutout begins to the edge of the camera plate.
2017 Series.Yellow
2013 Whiteout
The Following User Says Thank You to dhuang For This Useful Post:
gpvecchi (09-20-2018)
Old 09-20-2018, 01:47 AM   #20
gpvecchi
gpvecchi's Avatar
Great, many thanks! This is very very useful!
Old 02-13-2019, 01:32 AM   #21
hot_girl92
Drives: 2015 Subaru BRZ in WRB
Sorry to hijack, but besides the OEM camera, what did u use for the wiring?
hot_girl92 is offline   Reply With Quote
Old 02-13-2019, 01:47 AM   #22
gpvecchi
gpvecchi's Avatar
As I used an aftermarket radio, I cut the 4 pin connector of the camera and soldered a female RCA and a 7806 chip to feed 6V. Then I connected a couple of wires to reverse lights, and a male to make 75 Ohms RCA to the monitor.
BTW, the trunk trim is pre cut.
Old 02-13-2019, 04:01 AM   #23
hot_girl92
Ah i see. I think that might be out of my depth to attempt.
Thanks for the reply!
Old 02-13-2019, 04:50 AM   #24
JIM THEO
Drives: BRZ 2018
Isn't the 81811CA042 Cord - Trunk lid neccessary in order to install the rearview camera 86267CA500?
Or has he EUDM BRZ/GT86 this cord from the factory so it's plug and play?
Old 02-13-2019, 08:13 AM   #25
gpvecchi
gpvecchi's Avatar
Rear OEM camera is just for US and Australian market. If you have an aftermarket radio, my solution is the best. If you have stock one, you need to buy the trunk (and probably other) wiring, as there is no cord from factory. Or you can buy a genuine Subaru aftermarket camera.
Old 02-13-2019, 09:31 AM   #26
JIM THEO
Drives: BRZ 2018
I thought the wiring from the infotainment to the trunk is same for all countries and already installed, if it isn't and needs extra wiring except the trunk lid cord then it's too much job for my needs!
Old 02-13-2019, 01:40 PM   #27
Hey! Don't forget us.
Old 02-13-2019, 05:54 PM   #28
gpvecchi
gpvecchi's Avatar
Really? UK has it? I read the 2017 technical bulletin and it wasn't mentioned, just US and AU... Are you sure yours isn't the Subaru aftermarket?
Backup Camera input/recommendations for 2014 Monogram without factory Backup Camera RedLeaderD4S Electronics | Audio | NAV | Infotainment 3 08-04-2017 09:32 PM
100% Plug-&-Play Rearview Camera Installed from camera-source.com (Pics) zthang DIY (Do-It-Yourself) Guides 10 12-18-2015 05:14 PM
SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness NanDAssi Audio/Visual, Electronics, Infotainment, NAV 5 11-24-2015 06:06 PM
car camera Wherestheweed420 BRZ First-Gen (2012+) — General Topics 44 07-23-2015 05:00 PM
Contour GPS Camera Simmons Miscellaneous 2 01-28-2013 11:22 PM
