Drives: 2014 Scion FRS MT,2017 Toyota 86 AT
Seized motor/vapor lock after installing Edelbrock 1556
Hey all,
I spent the weekend installing the Edelbrock 1556 supercharger onto my 2017 Toyota 86. Full disclosure: I bought the supercharger used. Everything was seeming to go well with only having to modify the alternator power connection so the supercharger could fit. We double checked all hoses before we filled it up with coolant. When we started the car it started blowing a ton of white smoke out of the exhaust, and when we tapped the gas the engine completely stopped. When we took the intake off to inspect, tons of coolant was pouring out of the supercharger and onto the intake when we rotated the pulley by hand. At this point were not sure if the motor is completely hosed. We plan on taking the supercharger manifold off this weekend to try and take a vaccum to the inside of the engine to suck all the coolant out, then try to go back to my stage 2 e85 tune from delicious. My question is if anyone may have had this issue before, and if so how did they go about fixing it? We believe there may be a leak inside the supercharger itself, but it may be possible that we didn't do something right during the installation process that caused it. Any insight is appreciated Last edited by iceblaze; 09-17-2018 at 11:26 PM. |
#2 |
Drives: GT86
Cant help on why it happened as I'm not familiar with the kit, but I would say it would be a damage heat exchanger core in the manifold not holding water.
What I would say is 100% change the oil before trying to restart it |
#3 |
#1819
Drives: Lightning Red Subaru BRZ
Threads like these make me not want to buy a supercharger used. Sorry about what happened to you man.
#4 | |
#5 | |
Drives: 2017 BRZ
I wonder if the previous owner also blew his engine, then sold the kit w/o figuring out exactly what went wrong? Shipping damage? Yeah I just picked up a Cosworth kit from a local and am going to test this cooling circuit for leaks before install. |
#6 |
Drives: 2013 DGM BRZ
Hopefully your engine is okay and it's just an issue with the water heat exchanger within the SC manifold.
When you initially were priming the SC cooling system before starting the car, were you able to get it full? I'd imagine with a leak that big it would just indefinitely take coolant. |
#7 |
Drives: Q5 + BRZ + M796
Can’t you pull the core out of the rear and do a leak down test?
#8 |
Drives: 2015 Firestorm 08/05/15
If it’s the charger itself or the coolant core. Give Jon Bond performance a call he is the best in the buisness. Cheaper by far than Elderbrock. Keep us posted.
#9 |
#10 |
That and shouldn’t he also do a compression test? If he can spin the engine then maybe nothing major is wrong, but a compression test is necessary to confirm nothing subtle is wrong, right?
#11 | |
#12 |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
With the engine running and experiencing a hydro lock I would recomend disassembly. Since you are doing forced induction while you are in there you just as well replace rods/pistons instead of just inspecting. This will cost a lot less than if there is damage and you have the engine come apart later. Stress damage is not always visible.
#13 |
Drives: 2017 BRZ
With coolant in the oil, the bearing journals and cylinder walls may have scoring, and the VVT system may have experienced some abnormal wear. I'd be prepared for the existing engine not being a good core for rebuild.
#14 |
We didn't see any coolant in the oil when we pulled the dipstick, but we'll check for any scoring on the walls as well
| FS: Edelbrock Supercharger Kit 1556 (2012-15) FRS/BRZ (Sold) | rubbercow | Engine, Exhaust, Bolt-Ons | 5 | 08-27-2018 11:27 PM |
| FS: Edelbrock 1556 Supercharger Kit [Sold] | rubbercow | Engine, Exhaust, Bolt-Ons | 4 | 03-14-2018 07:15 PM |
| Installing 2016 Motor in 2013 Car | Sojhinn | Software Tuning | 15 | 08-12-2017 06:29 PM |
| Seized Motor - Need options/help | GWiZ | Issues | Warranty | Recalls / TSB | 33 | 03-13-2015 05:36 PM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
