Old 09-16-2018, 10:58 PM   #15
Originally Posted by RenegadeReaper View Post
After going over what I did with a rather knowledgeable mechanic in my town I think I figured it out. If the crown plate that Ultramaroon mentioned is what the crank sensor is reading then I probably didn't put it back properly, there should be marks that I have to line up right? So atm even though the rpm is right the sensor is picking up the wrong crank position.
It can fit one of two ways. As an engineer, I am disappointed that they didn't consider making it completely idiot proof with a slight angular offset of the guide pin. Totally free feature.
:/ design-for-service fail.
https://demos.starbase7.net/t3Portal...041LF007X.html
If you're getting an RPM value, it's mounted properly.
Old 09-16-2018, 11:00 PM   #16
RenegadeReaper
Drives: 2013 Frs
Check out my build. I have pics of my clutch install and the correct plate orientation.
Thanks, I didn't remember the pin to keep it aligned, which means It might be correct anyway, but I'll probably drop the trany anyway to make sure because I don't have any more Ideas.
RenegadeReaper is offline   Reply With Quote
Old 09-17-2018, 08:26 AM   #17
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Why are people on this forum so eager to tear stuff up?
There's an access cap opposite the crank sensor, it's used to unbolt the torque converter from the flexplate on automatics. There's nothing to unbolt on a manual, but you can clearly see if you've reversed the reluctor wheel without removing the transmission. The teeth should point towards the engine.
Of course, the wheel may in installed the right way, but indexed wrong... if you don't remember there being an indexing pin, maybe it fell during disassembly... And that won't be visible through the access hole.
But it never hurts to do low effort checks before high effort removals.
The Following User Says Thank You to RZNT4R For This Useful Post:
Tcoat (09-17-2018)
Old 09-17-2018, 01:43 PM   #18
I'm going to stick up for myself a little because this hit a nerve even though I'm pretty sure it wasn't aimed at me. I spent over 8 years in the Navy fixing shit that was broken or worn out mainly due to excessive preventative maintenance. I detest unnecessarily disassembling anything so I put extra effort into making sure I get it right the first time. That comes with experience.
I also learn new stuff on this forum all the time. Today I was reminded that there's a nice inspection port on top of the engine. Never even considered it.
Old 09-18-2018, 08:37 PM   #19
RenegadeReaper
Drives: 2013 Frs
Man do I feel dumb, I just pulled the trans and it turns out I put the reluctor wheel on 90 deg off. To be clear (RZNT4R) I knew it was facing the engine the whole time but I never lined the pin up. This was the first trans I ever pulled but its the last one I'm going to rush. I'm going to take my time putting it back together now.
Old 09-19-2018, 03:20 AM   #20
How were you able to mount the flywheel? Wasn't it visibly crooked?
Old 09-19-2018, 09:29 PM   #21
RenegadeReaper
Drives: 2013 Frs
not nearly enough to notice, the pin on the engine side wasn't any more than 1/32". It's enough to catch the hole, but the flywheel seemed to torque down just fine over top of it. I should stress that I never even took the wheel off, and therefore didn't see the pin the first time.
The Following User Says Thank You to RenegadeReaper For This Useful Post:
Ultramaroon (09-19-2018)
Old 09-19-2018, 10:21 PM   #22
Wow. That's crazy. I haven't had the flywheel off of mine yet but, based on previous experience, I can picture how it all went down for you.
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 06:36 PM
No-start after clutch install chargedup Engine, Exhaust, Transmission 11 03-27-2017 06:22 PM
car won't start after clutch installed aquaman Issues | Warranty | Recalls / TSB 4 07-19-2016 02:29 AM
How to change the start up screen on 2014 head unit? Choob Electronics | Audio | NAV | Infotainment 9 08-03-2014 07:24 PM
GTS Sat Nav Start Up Screen change? MacTec AUSTRALIA 6 12-31-2012 05:10 AM
