Drives: 2013 Frs
Won't start after clutch change
I have a 2013 Frs. Several weeks ago I put a new ACT street clutch and LW flywheel in it. After putting it all back together It won't cranks but won't start. I've already checked a lot of things:
No ECU codes has fuel pressure no blown fuses all connectors securely reconnected no pinched wires crank sensor replaced It ran perfectly before, but now when I turn the key it just cranks, it will pop kind of like a backfire every few seconds. It seems like the timing got thrown off but I was hoping someone here could give me some more info before I pull the cover. While I have heard that turning the flywheel backwards (I did this while torquing the FW) could cause a timing belt to skip is that even possible with the chain on these engines? |
#2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
"no ecu codes"
"crank sensor replaced" If you've got an obd scan tool, did you check the engine rpm PID while cranking? |
#3 |
Hello RenegadeReaper and welcome to - The Forum -
![]() We have some pretty smart folks on the forum that may be able to help you out - but, I ain't one of them - ![]() Someone will be along soon. humfrz |
#4 |
Drives: 2013 Frs
@RZNT4R
"no ecu codes" "crank sensor replaced" To be more specific, I have and Open Flash Tablet which will give any cel codes. after checking my wires and making sure the fuel pump was working I replaced the crank sensor because with what info I could gather it seemed like the most likely culprit. It wasn't. "If you've got an obd scan tool, did you check the engine rpm PID while cranking? " Are you referring to the realtime data through obd2? Does the ecu use the crank sensor to calculate this? I didn't think of that before, but it's always matched the gauge roughly so i guess that would mean it's reading properly. or am I wrong? @humfrz Thank you and I hope you're right. None of the mechanics in my area are familiar with these cars. |
#5 |
Take it all back apart and flip the crankshaft position scale around. The teeth are supposed to face forward, away from the flywheel.
It's a common mistake.
#6 | |
It's easy to check as it requires no disassembly. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Ultramaroon (09-15-2018) |
#7 | |
Drives: 2013 Frs
Well I have confirmed that the problem is not the sensor, but what are you referring to by the "scale?" The only thing I remember with "teeth" was the flywheel itself, and the plate behind it was definitely facing away. |
#8 | |
People do install it backward. Try RZNT4R's idea of reading the RPM.
#9 | |
Drives: 2013 Frs
TBH I'm not sure what reading the rpm is supposed to tell me other than that the crank sensor is working. I originally thought that I might have damaged the sensor while replacing the flywheel but since I already replaced it, that apparently wasn't the case. I was hoping to get some other ideas as to what might be wrong. the short version is: still have fuel, air, spark, and no cel codes but it won't start and the timing doesn't sound right. |
#10 | |
#11 | |
![]() OK, folks, how does one check the timing on these new fangled machines?? I was good with a couple of lengths of wire and a 12V light bulb and later on a timing light - but, today, I have no idea. The OP needs help! Anyone? humfrz |
#12 |
By looking at the live data you're looking for a low or intermittent reading. The crank sensor is (surprisingly) a pretty old school AC voltage generator, if it or it's reluctor are misaligned, sufficiently high AC voltage can't be generated.
| The Following User Says Thank You to RZNT4R For This Useful Post: | Ultramaroon (09-16-2018) |
#13 |
Drives: 2013 Frs
After going over what I did with a rather knowledgeable mechanic in my town I think I figured it out. If the crown plate that Ultramaroon mentioned is what the crank sensor is reading then I probably didn't put it back properly, there should be marks that I have to line up right? So atm even though the rpm is right the sensor is picking up the wrong crank position.
#14 |
Drives: Q5 + BRZ + M796
Check out my build. I have pics of my clutch install and the correct plate orientation.
| Help! Is there anyway to change the 2017 cluster start up image? | slashlee | DIY (Do-It-Yourself) Guides | 2 | 11-17-2018 06:36 PM |
| No-start after clutch install | chargedup | Engine, Exhaust, Transmission | 11 | 03-27-2017 06:22 PM |
| car won't start after clutch installed | aquaman | Issues | Warranty | Recalls / TSB | 4 | 07-19-2016 02:29 AM |
| How to change the start up screen on 2014 head unit? | Choob | Electronics | Audio | NAV | Infotainment | 9 | 08-03-2014 07:24 PM |
| GTS Sat Nav Start Up Screen change? | MacTec | AUSTRALIA | 6 | 12-31-2012 05:10 AM |
