Old 08-30-2018, 07:09 PM   #15
86MLR
86MLR's Avatar
Originally Posted by Scala View Post
+1 but most people prefer to fool themselves.
And yet it didn't effect mine.
You do know resonators are designed to muffle sound frequencies, that's why there are so many, at the snorkle, airbox an induction pipe.
Lots of R&D went into these little tanks IRT having the vehicles noise level compliant.
But, as always, opinions may vary.
Old 08-31-2018, 11:15 AM   #16
Scala
Drives: 2018 BRZ tS
So you removed all the "little tanks" and this "didn't effect" your car?
No documented power loss or gain or sound change?
Did you do other modifications at the same time or just that?
Scala is offline   Reply With Quote
Old 08-31-2018, 02:45 PM   #17
re-animator
mishimoto posted some numbers that came when they messed with the resonator while designing their intake let me see if i can find it...
turns out removing the resonator actually hurts power:
https://www.ft86club.com/forums/showthread.php?t=61621
re-animator is offline   Reply With Quote
Old 08-31-2018, 03:07 PM   #18
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Did you A/B/A test your results on a dyno? Do you have data backing this claim? Intake design is far more complicated than it ever was. Yes, part of the job for those chambers is to reduce noise but their primary job is to improve the volumetric efficiency of the intake and improve power. Check out the article HERE for more information on this subject.
The factory intake system on most cars are so well designed at this point, it isn't rocket science why aftermarket intakes don't work. Look at most intake systems for this car, they "improve" power slightly on a dyno but in the real world transient throttle response turns to garbage. Hard for a straight piece of pipe to emulate a computer designed and engineered system of resonance chambers to ensure smooth airflow across the MAF.
Lincoln Logs is offline   Reply With Quote
The Following 4 Users Say Thank You to Lincoln Logs For This Useful Post:
chaoskaze (08-31-2018), MuseChaser (09-14-2018), re-animator (08-31-2018), Tristor (09-14-2018)
Old 08-31-2018, 03:09 PM   #19
Scala
Drives: 2018 BRZ tS
Thank you re-animator.
Exactly my experiences and those of other Miata NA/NB racers and countless dyno tests. You remove the Helmhotz chamber and you pay for it.
Old 08-31-2018, 07:01 PM   #20
86MLR
86MLR's Avatar
Didn't dyno.
Generally when I do something I see how my 0 - 100 goes.
Both the dyno and the 0-100 have inherent flaws though.
As for the resonator on the intake tube, opinions and results vary, you say it looses power others say it doesn't, why wouldn't the TRD airbox have one?
I'm not buying it, especially when dyno results are brought up, I've seen so much variation over the years, trying to pick one or 2 horsepower isn't going to be repeatable, you can fudge the graph quite easily though to give you any result you want.
IMO dynos are for tuning and circlejerks, 0-100 and the 1/4 mile will tell the truth.
I'm just posting my findings.
Enjoy
Old 09-01-2018, 11:49 AM   #21
Lincoln Logs
Didn't dyno.
Enjoy
Dynos are not perfect tools and they are often used incorrectly for testing. Real dyno testing needs to happen with the car strapped to the dyno and you make changes to the car right there and test again. The way you strap a car down on the dyno can effect numbers so even coming back the next day to the same dyno can skew results.
Resonance chambers are not always required if the design is correct. I suspect the design of the TRD box accounts for that, those folks know a thing or two. Keep in mind that the TRD airbox fits to the factory snorkle which has resonance chambers on it as well, so it doesn't lose all of them.
Old 09-01-2018, 07:49 PM   #22
86MLR
86MLR's Avatar
From here > http://www.ft86club.com/forums/showt...=129897&page=3
The Following User Says Thank You to 86MLR For This Useful Post:
Old 09-14-2018, 11:27 AM   #23
vandemo1133
Drives: 2015 FRS
installed incorrectly?
I have the perrin intake with a perrin inlet tube and doesn't make that suction noise that people talk about for some reason. Is it possible it was installed wrong? Does clamping or loosening the clamps a bit contribute to a better sound at all?
vandemo1133 is offline   Reply With Quote
Old 09-14-2018, 11:53 AM   #24
tomm.brz
Drives: brz 2017 hksv2
the Perrin CAI?
tomm.brz is online now   Reply With Quote
Old 09-14-2018, 12:01 PM   #25
vandemo1133
Drives: 2015 FRS
Originally Posted by tomm.brz View Post
the Perrin CAI?
Yes sir!
Old 09-15-2018, 09:24 AM   #26
Mr_Eyo
Drives: 2017 Toyota 86
Is there a noticeable under the hood induction nsound change going from stock to sound tube delete?
Mr_Eyo is offline   Reply With Quote
Old 09-15-2018, 09:27 AM   #27
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
In my opinion no. But that varies greatly depending on who you ask. Unplug it at the firewall and go for a drive, it's really easy.
Old 09-15-2018, 11:50 AM   #28
churchx
churchx's Avatar
Drives: 2014 GT86
Simplest is to not unplug anything. Just plug hole from inside cabin with reusing second ciglighter socket plug from glovebox. No need to buy anything or even lifting hood to just test of how it's w/o soundtube. It's very subjective feel, but with 100% stock exhaust by i had wrong & subjective feel car becoming weaker/limp a bit, so stayed with that soundtube left functional. Probably wouldn't need to, if i had aftermarket exhaust.
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
easy OEM Sound System Upgrade with DSP OnkelC Electronics | Audio | NAV | Infotainment 0 05-24-2015 10:12 AM
Easy in-cabin Subwoofer Upgrade JayNutter Electronics | Audio | NAV | Infotainment 17 12-17-2012 05:51 PM
Easy In-Cabin Subwoofer Upgrade (FR-S or BRZ) JayNutter Electronics | Audio | NAV | Infotainment 1 12-05-2012 12:41 PM
Inexpensive suggestion for better sound?? ngabdala Electronics | Audio | NAV | Infotainment 28 08-24-2012 01:05 PM
