Old 03-25-2014, 01:14 PM   #1
Mishimoto
Drives: 2013 Subaru BRZ
Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake
Hey guys,
We are currently hard at work to develop a performance cold-air intake for the BRZ/FR-S! This project has been fascinating thus far, and we are documenting the developmental process in this build thread. By doing so we can provide an inside look at the time and effort our team puts into each product we design. It also presents a chance to display the skill-set of our engineering team and highlight performance data and unique features of our new products.
Check out the build below and feel free to follow up with any questions, comments or suggestions!
This project build and many others can be found on our new Engineering Blog! Check it out if you have a moment. 2013+ Subaru BRZ / Scion FR-S Performance Cold-Air Intake, Part 1: Product Introduction and Goals
These articles normally begin with a quick background of the vehicle in question, followed by some of the performance high points and pitfalls of the car. With this particular vehicle, this process is not necessary. If you are reading this, you probably already own a BRZ/FR-S, and/or you are well aware of the effect this vehicle has had on the automotive world. Autocross, track days, drifting, daily driving, even rally; the 86 has everything you need to really enjoy yourself behind the wheel in any setting. Mishimoto dove headfirst into the performance cooling market, releasing several innovative cooling products already well known for other chassis. Our current product list for the BRZ/FR-S includes a performance aluminum radiator, silicone radiator hose kit, direct-fit oil cooler kit, low-temperature thermostat, silicone induction hose, and some really smart-looking oil fill caps! With our main product lines covered, it was time to move into our brand-new line of air intakes. We recently released a performance cold-air intake for the 2008+ Subaru WRX/STI, and we had a ton of success adding some easy bolt-on power (25 hp / 25 tq on a stock STI). Our new facility has a fantastic Dynojet that has been pivotal in providing the data we need to support our products and to give the end consumer some insight into what our products will do for them in the real world.
Each of these articles provides a step-by-step look at how our team fabricates, designs, enhances, and tests each of our products. Our goal is to create the absolute best product we can, from concept to completion. This product is then shipped in cutting-edge packaging to make its way into the hands of a salivating customer. All right, so maybe some of you are not quite as enthusiastic as I am when car parts are on the way, but this article will help shed some light on what Mishimoto is all about! Check out the Dynojet!
Mishimoto Dynojet
With their experience in designing intakes and a variety of other complex products, our team of engineers was ready to tackle this project. When we developed our silicone induction hose, we conducted a ton of testing and data collection to show the effects of replacing the factory hose as well as the consequences of eliminating the resonator and noise generator. The results were quite interesting!
Testing results for Mishimoto silicone induction hose
Utilizing the Mishimoto induction hose and a high-flow panel air filter, and with the noise amplifier removed, we were able to gain 6 horsepower and 3 torque over the all-stock setup. We also saw a loss in power with the resonator removed, so the resonator should be retained if you are using the factory airbox setup. During this testing we saw quite a bit of room for improvement for the stock intake. Most factory intakes are designed with several restrictive points, which can provide an opportunity for some easy power. Less restriction on both the intake and exhaust portion of the engine will net greater flow and improved power.
We set out to create a few goals that would help our team in designing a very efficient and successful intake.
Goals
  1. Direct-fit unit requiring no modification to the vehicle
  2. Intake should pull cold air from outside the engine bay
  3. Include Mishimoto high-flow air filter
  4. Improve horsepower and torque
  5. Air-to-fuel ratio (AFR) should be safe during all driving conditions
  6. Install should be simple and well documented
  7. Improve intake noise to delight the auditory senses of the driver, passengers, and any lucky bystanders
Direct Fit
Our first goal is rather simple and quite common for a majority of our products. Depending on the vehicle application, project strategy, and consumer wants/needs, at times our team will stray from this goal. However, direct fit is typically a requirement. Although we have no issues with removing OEM components, any serious cutting or trimming is something we try to avoid. For this particular product we are required to remove the factory airbox, which occupies a space right above the radiator and inside the hot engine bay. We intend to develop a cold-air intake that will pull air from outside of the engine bay. We hope to avoid any additional modifications, but this will depend on the design that our engineers select. We are certainly willing to trade some minor modification for an increase in performance. We also understand that most owners would not be interested in taking a grinder or cutoff wheel to the core support of a brand-new vehicle.
Cold-Air Intake
This second goal was one we also worked with for our WRX/STI intake kit. To eliminate the influence of engine bay heat on intake temperatures, we would be attempting to place our filter in a cooler environment that has a nice stream of airflow. Just so everyone is on the same page, cooler intake air is certainly better and results in a nice dense charge of air that allows for improved combustion. Our goal would be to reduce air temperatures and eliminate any heat soak that might occur with a system that is located in the engine bay.
High-Flow Filter
As with our other intake kits, the BRZ/FR-S kit will include a Mishimoto high-flow air filter. Now, just because these filters outflow the OEM counterparts, this does not mean they have less filtration ability. Our filters are completely serviceable to provide a lifetime of consistent performance. Our oiled filters are exceptional at capturing dirt and debris, and they provide superior airflow compared to factory paper filters. Each filter also includes a lifetime warranty! Awesome! Check out one of our filters below.
Add Power
Unfortunately, intake design is not as simple as throwing the filter on the end of a pipe and calling it a day. Our engineers would be working on removing restrictions, improving airflow, and generating correct AFRs to produce a safe product that improves both horsepower and torque. Although the BRZ/FR-S was not designed with outright speed in mind, a few extra ponies certainly wouldn’t hinder the overall driving experience. No, you will not melt tires in fourth gear or pass an Evo on the straights, but a little extra punch might help you knock down those lap times or improve your position at the local autocross. We do not have any set goals for power; however, we are hoping to extract as much as we can in a safe manner.
Safe AFRs
One easy way to squeak out some power is to lean out the AFR mixture. Factory tunes are often set to run rich as a safeguard for any potential engine damage, and to regulate exhaust gas temperature (EGT) properly. By leaning out the mixture, one can obtain a more efficient burn and therefore more power. While this maneuver is generally safe, some aftermarket products take it a bit far, even to the point of potentially damaging your FA20. A fuel mixture that is too lean is a great way to evoke engine knock, detonation, and/or blow holes in the pistons. Although these effects are rare, they should certainly be considered when selecting an intake, which will affect the AFR of your engine. Typical tuners tend to shoot for a ratio of around 12.7:1 under full throttle. This ratio is perfect for a naturally aspirated (NA) engine, but boosted engines require a much lower ratio, somewhere in the range of 11:4 to 12:1 depending upon engine/turbo factors. This is important to keep in mind, as many aftermarket options for the BRZ/FR-S dip well into the 13s and even the 14s under full throttle in the higher rpms. Personally, I would not feel comfortable installing this on my vehicle. Our team will be monitoring AFRs throughout testing to best follow the factory curve. Our end product will not be dipping into the danger zone just to tout the biggest power gains.
Ease of Install
Not only do we want this intake to perform, but we also would like it to provide a clean appearance in your engine bay. Our product should install fairly easily with common hand tools and be simple enough for the weekend shade-tree mechanic. BRZ/FR-S owners seem to be a diverse bunch with varying levels of mechanical aptitude. We are going to do our best to design a product that everyone can install easily. As usual, we will be including a very detailed installation video that will provide step-by-step instructions for installation.
Improve Engine Tone
Now on to everyone’s favorite part, noise! A good intake growl is sure to impress your friends, relatives, and work colleagues. Treat them to a symphony of flat-four goodness every time you stomp on the pedal. Yes, this is a secondary goal, but we expect to provide some improved engine noise tones through the development of our intake.
Now that we have our goals out of the way, it was time to take a good look at the engine bay of an 86 and see what direction we wanted to go with our design. Luckily a member of our accounting team happens to daily drive his FR-S, so this would be simple! Even better, this engine bay was completely stock. Check it out!
FR-S stock engine bay
The stock engine bay on these cars is extremely well laid out. We should thank Toybaru designers for creating a spacious bay with room to innovate and modify this wonderful car. Once we had a look at the stock setup, it was time to pull the airbox out and see how much room we had to work with.
FR-S stock engine bay with intake removed
The stock intake takes up quite a bit of real estate in the engine bay. The intake box is situated right over the top of the radiator, meaning that heat soak would certainly be a possibility, as coolant temperatures should be hovering around 200 degrees. The box pulls air from the front bumper area via a scoop/duct, which you can see peeking out from under the core support.
FR-S stock intake box
Here we have the factory intake box complete with resonator assembly. You will notice the mass air flow (MAF) housing as well, just before the connection point with the rubber inlet hose. We already have a very successful product in place for the induction hose, so we would be designing our intake from the end of the induction hose to the filter. Our design would need to incorporate the MAF mounting point as well as an air straightener to provide smooth, consistent MAF readings.
FR-S stock intake box and its respective home
With our engineering group together, the brainstorming began! And quite a storm it was. We had ideas for a boxed system, a true cold-air setup, and discussions about performance panel filters. After much debate, it was decided that we would develop a true cold-air intake and run the intake piping into the bumper area. We plan to route this in similar fashion to the stock ducting and use one of our high-flow filters. For improved airflow we discussed the use of a diverter plate to channel more cold air to the filter. Our design would require some extensive fabrication and design. Check back with us next time as our team starts the development process of our new intake!
Thanks
Mishimoto is offline   Reply With Quote
Old 03-30-2014, 03:28 AM   #2
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Looks sick guys, awaiting updates !
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 03-30-2014, 03:38 AM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Here's to hoping what's being developed does not require taking off bumper for a filter change? I'm assuming true CAI may make removable necessary but here's to hoping I may be wrong. As far as piping & avoiding heat soak I assume a coating like white lightning type ceramic coating?
Grim speeds been developing one to that's very involved. Who wins the race with a true well working product. That's the question! nice to see yet more options.
Old 03-30-2014, 08:22 AM   #4
Basket Case
Drives: 2013 Raven fr-s
I'm hoping that someone finds a way to make a little power with an intake. It is always nice to actually make more power with bolt ons.
Basket Case is offline   Reply With Quote
Old 03-30-2014, 09:39 AM   #5
Nicky
Nicky's Avatar
Drives: '05 Acura TSX, '14 FRS (Asphalt)
Awesome!
Nicky is offline   Reply With Quote
Old 03-31-2014, 12:52 AM   #6
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Subscribed
MINOCIN is offline   Reply With Quote
Old 03-31-2014, 01:28 AM   #7
Blue14inTracy
Drives: 2014 FR-S
looking forward to a good CAI soon. hope you guys won't make us wait to long
2014 Scion FR-S: Beatsonic shark fin, Grimmspeed Inatke
Blue14inTracy is offline   Reply With Quote
Old 03-31-2014, 09:28 AM   #8
Mishimoto
Thanks for following!
Thanks! Our current plan does involve removing the bumper for filter servicing. Luckily, this is only necessary every 15,000-20,000 miles and the removal process is fairly simple. Our install guide will cover the proper method for removal and servicing. We will provide testing data once we get further along in the development process. Stay tuned.
Exactly the plan!
Originally Posted by Nicky View Post
Awesome!
Originally Posted by MINOCIN View Post
Subscribed
Thanks for following along!
Thanks! We are hard at work to complete this kit! We should have a more accurate timeline for release in the upcoming weeks.
Old 03-31-2014, 09:45 AM   #9
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
One note that you may want to take is that many members do not like removing the front bumper. Many members have had problems with clips not "biting" after removal. The problem that I have seen are the clips under the headlights, and there is no effective solution that I have seen yet.
The resulting problem is the bumper protrudes too far out/forward at the rearward upper edge. You should let us know if you have the same problem!
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 04-01-2014, 09:39 AM   #10
Mishimoto
Noted, thanks for the recommendation. We have had the bumper off our test vehicles numerous times with little issues. The clips are a bit of a pain, but with proper instruction, bumper removal is a rather smooth process. We will be sure to provide easy to follow instructions for this process. A majority of our products include an installation guide video, this kit will be no different.
Thanks
Old 04-01-2014, 11:49 AM   #11
Simon99
Simon99's Avatar
Thanks
Keeping the noise generator wont be an option I guess ?
Sent from my SGH-I337M using Tapatalk
Old 04-01-2014, 11:53 AM   #12
OICU812
Just a dude
OICU812's Avatar
Noise generator is a joke anyhow. Once removed I'd never put it back on, like (ever).
Old 04-01-2014, 11:59 AM   #13
Crazy Drew
Drives: Smells like tires when I drive
Crazy Drew is offline   Reply With Quote
Old 04-01-2014, 02:30 PM   #14
Simon99
Simon99's Avatar
I know that but an option like takeda/greddy could be offered..
Mishimoto Needs Your Help With Our BRZ/FR-S Intake! Mishimoto Engine, Exhaust, Transmission 10 03-31-2014 09:30 AM
FS: MISHIMOTO INTAKE TUBE BlackyRose Engine, Exhaust, Bolt-Ons 4 03-09-2014 04:17 PM
Testing Our New Vortech Cold Air Intake @ Pure Automotive Performance! Dyno's Inside! Pure Automotive Forced Induction 24 10-20-2013 11:29 PM
AMR Performance: Cold Air Intake System - BRZ/FR-S/GT86 AMR Engine, Exhaust, Transmission 10 04-11-2013 11:37 AM
*Pure Automotive Performance: Project Whiteout FRS Build Thread* Pure Automotive Member's Car Journals 6 01-18-2013 11:34 AM
