Old 09-04-2018, 11:30 PM   #1
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Gear lockout / grind
So I was on neutral. While fully pressing the clutch, I put it in first gear. However, it wouldn't go in. So I let go to have it go back on neutral. Rev'd it up, and tried putting it again. Since I didn't go through, I tried forcing it in. It went half way and started wiggling/vibrating. It also made a notchy sound, rather than a screeching sound. Then it spat it out. Keep in mind that my foot was on the clutch the whole time.
Is there a solution for this? How severe good I do to the car?
I I have stage 3 ceramic clutch for manual transmission. And have 80000 Miles
Thanks!
Sent from my SM-G965U using Tapatalk
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 09-05-2018, 12:41 AM   #2
Fix your clutch.
Old 09-05-2018, 04:41 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Sounds like clutch drag of some sort. Time to drop the trans
EndlessAzure is offline   Reply With Quote
5th gear grind Hugo Issues | Warranty | Recalls / TSB 7 06-08-2016 09:33 AM
4th gear grind dallenj Engine, Exhaust, Transmission 15 06-03-2016 05:04 PM
5th and 6th gear grind... Basket Case Engine, Exhaust, Transmission 7 02-11-2015 09:53 PM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 06:47 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
