Old 08-19-2018, 07:24 PM   #1
dynomite619
dynomite619's Avatar
Drives: 2016 subaru brz insta@black.xira
major issue
so i had a thread about a dash fuse 7.5 blowing up already and i though it was the airbag module then my fuse started blowing out weeks later and it was a 15 fuse not a 7.5 and it starting become an issue and it just cuts off my alternator and now my power steering! i just wanna know what options i can do find a solution or im just drive it up the dealership .
my car : http://tinypic.com/r/2eok7l4/9
dynomite619 is offline   Reply With Quote
Old 08-19-2018, 10:05 PM   #2
Fuse blowing is a symptom not a cause. If you just keep replacing the fuse you are doing it wrong.
Need to find the root cause. Did you change anything at all before they started blowing?
BirdTRD (08-20-2018), Stang70Fastback (08-19-2018)
Old 08-19-2018, 10:31 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I'm confused. Did the same fuse blow up both times? Did you replace the 7.5A fuse with a 15A fuse? If you did, you need to step away from the vehicle before you make things any worse. Fuses are there for a reason, and they are a spec'd to their respective limits for a reason too...
As Tcoat said, a fuse blowing is a symptom. It is a last line of defense before you fry something on the car. You need to find out what is causing the fuses to blow. We may be able to help, but we at least need more specifics.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 08-20-2018, 07:35 PM   #4
dynomite619
yes i have replaced a 7.5A with a 15A fuse ,like this fuse is the dash and without it there are no turn signals the alternator doesnt charge and when it dont charge and run the electricals the power steering goes out and the ecu of the car goes off which dies out the car.
Old 08-20-2018, 07:55 PM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
These are all the systems that fuse is setup for. I would advise to see a dealer. Also, don't change the fuse Amperage from what it came with. It's set at that amperage for a reason.
7.5A GAUGE
ABS
Air Conditioning
Charging
Clock
Combination Meter
Cruise Control
Electronically Controlled Transmission and A/T Indicator
Engine Control
Engine Immobiliser System
EPS
Headlight
Illumination
Key Reminder
Light Reminder
Seat Belt Warning
Shift Lock
SRS
Taillight
Tire Pressure Warning System
TRAC
Turn Signal and Hazard Warning Light
VSC
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
dynomite619 (08-21-2018)
Old 08-20-2018, 08:12 PM   #6
Stang70Fastback
A.K.A. Starlord
That is ABSOLUTELY the wrong thing to do. You need to bring the car to a shop and have it looked at by someone who knows what they are doing. You are going to cause MORE damage to the car with your actions. Putting a fuse in with twice the current capacity after the original one blows is the WORST thing you can do. You are literally doing the exact opposite of what the fuse is intended to do - stop an electrical overload from frying electronics, melting wires, or starting a fire.
You need to stop driving the car, and bring it somewhere to be serviced. If your car catches fire and burns, and your insurance company finds out you doubled a fuse, they could very easily deny your claim on the basis of negligence and intentional misuse.
The Following 5 Users Say Thank You to Stang70Fastback For This Useful Post:
BirdTRD (08-21-2018), Cheeky (08-21-2018), humfrz (08-20-2018), Tcoat (08-20-2018), Ultramaroon (08-20-2018)
Old 08-20-2018, 08:32 PM   #7
OP, listen to what these guys are telling you. Pull that 15A fuse now and quit driving it.
Have it towed to an expert.
humfrz (08-20-2018), Stang70Fastback (08-20-2018), Tcoat (08-20-2018)
Old 08-20-2018, 08:49 PM   #8
He was already told this almost two months ago but didn't listen then so doubt he will now.
The "My car burned up and it is Subaru's fault" thread should come any day now.
https://www.ft86club.com/forums/showthread.php?t=128611
humfrz (08-20-2018), Stang70Fastback (08-20-2018), stevesnj (08-20-2018), Ultramaroon (08-20-2018)
Old 08-20-2018, 09:47 PM   #9
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Reading OP's responses like...
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 3 Users Say Thank You to Shark_Bait88 For This Useful Post:
Stang70Fastback (08-20-2018), Tcoat (08-20-2018), Ultramaroon (08-20-2018)
Old 08-20-2018, 09:56 PM   #10
Ho-lee crap! It did sound awfully familiar.
Old 08-20-2018, 09:59 PM   #11
strmshadow84
Drives: 14 Cayman S, 16 Camaro 2SS
All these guys are absolutely right. You probably have a short somewhere in your system and by replacing it with a higher fuse your potentially allowing other systems to have more power (which=heat) flow to them then they were designed for. Take it to the dealership and allow them to figure out whats going on with your car.
strmshadow84 is offline   Reply With Quote
The Following User Says Thank You to strmshadow84 For This Useful Post:
Old 08-20-2018, 10:12 PM   #12
Ain't nutten wrong with ol Tcoat's short term memory -
Better than I can say for ol @Ultramaroon 's -
OP, I suggest you just give your car keys to someone else and ask them to arrange to have your car fixed. I'm afraid this situation is waaaay over your pay grade.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Old 08-20-2018, 10:32 PM   #13
Sooooo... I gotta ask. Did you ever disconnect the amp that started all this?
https://www.ft86club.com/forums/show...38&postcount=6
https://www.ft86club.com/forums/show...59&postcount=9
Old 08-20-2018, 10:49 PM   #14
stevesnj
stevesnj's Avatar
Where did you wire your amp to? which terminal shown on this pic?
My 2016 Build thread
Major service Fletchlives78 AUSTRALIA 18 03-08-2017 06:22 AM
Known Major Issues I should know about.... Darkone BRZ First-Gen (2012+) — General Topics 41 01-04-2017 10:51 PM
Major Mods.. Jaden Scion FR-S / Toyota 86 GT86 General Forum 72 08-28-2015 11:16 PM
Rattles are a major issue in this car jflogerzi Issues | Warranty | Recalls / TSB 49 11-05-2012 11:59 AM
One fairly major and one minorish issue.... Jedi1 Tracking / Autocross / HPDE / Drifting 3 07-31-2012 04:08 PM
