Old 08-16-2018, 09:18 PM   #1
qqzj
Drives: MDX, Camry
Why is my BRZ idling so rough?
Long-time 2013 BRZ owner here. Car is about 5 year old with 37k miles. One thing I am concerned about it that the car idles petty rough, especially when it is still cold. I feel like the connection rods has a bad bearing (of course I don't really know). It has been this way since new and I have a pretty peaceful 5 years now. Should I be concerned that it is an exploding bomb? I still have a couple of month drive drain warranty. Not sure whether I should take it to a dealer to have a look.
Any ideas? Thanks.
qqzj is offline   Reply With Quote
Old 08-16-2018, 09:24 PM   #2
Any ideas? Thanks.
There are 1,000 things that could cause it to "run rough". Need a pile more info or even better a video to even make even a remote long shot guess (although there will probably be loads of people that will be happy to tell you what is wrong). If it has done it since new I highly doubt that it is rod bearings or it would have blown long ago.
Old 08-16-2018, 11:12 PM   #3
Lantanafrs2
Drives: 2013 frs red
Hasn't it been to a dealer already? It has 37k on it.
Lantanafrs2 is offline   Reply With Quote
Old 08-16-2018, 11:35 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Any ideas? Thanks.
What lantana and tcoat said^
So many things can cause a rough idle condition. Do you have any mods?
Either way you said it yourself go to the dealer while it still has time left under warranty and get it checked out, if they don't find anything take it to another Subaru dealer if possible to confirm. Also 37k miles is pretty low for a 5 year old BRZ which is pretty cool.
Old 08-17-2018, 12:10 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Have you tried turning the "idle roughness adjustment screw?"
FRSBRZGT86FAN (08-17-2018)
Old 08-17-2018, 12:33 AM   #6
factory ghost cam
chaoskaze (08-18-2018), FRSBRZGT86FAN (08-17-2018)
Old 08-18-2018, 03:50 AM   #7
qqzj
Drives: MDX, Camry
It is quite hard to describe the feeling. I kind of suspect that it is a Subaru design issue. Piston and connecting rod of a Boxer should move in a roughly horizontal plane. But I feel that while it is idling, there are some additional vibration on the vertical plane. I was hoping that someone else who experienced it can explain to me what is going on. But scratch that.
Old 08-18-2018, 04:57 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
@qqzj There is a reason that 4-cyl Boxer engines have rough idle. It is on their inherent design, because of the firing order LLRR or RRLL.
Old 08-18-2018, 06:12 AM   #9
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
So would a 6cyl boxer engine be more in balance?
LRL+RLR or RLR+LRL
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 08-18-2018, 06:19 AM   #10
tomm.brz
Drives: brz 2017 hksv2
what you mean with rough? that the rpm oscillate or that the car vibrates? it rpm oscillate i m pretty convinced it a becayse the stock tune that add PI already starting from 0.2 of engine load and PI and DI are never match-scaled properly
i fixer the rpm oscillating in every tune I did removing PI untill 0.4 engine load and reducing a bit port scalar from 228 to 222 or 224
Old 08-18-2018, 06:49 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
LRL+RLR or RLR+LRL
Yes it should be more in balance:
The Following User Says Thank You to nikitopo For This Useful Post:
Adam_L (08-18-2018)
Old 08-18-2018, 09:16 AM   #12
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea the stock tune has a garbage idle, especially on the early cars.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
norcalpb (08-18-2018)
Old 08-18-2018, 02:02 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Find someone with another one and see how it compares to yours. When I first started out with this car that's what I did every time I heard a weird noise or something.
Old 08-18-2018, 02:34 PM   #14
norcalpb
norcalpb's Avatar
Yup, 2013 tune sucks OP needs an OFT to slightly raise your idle.
Odd noise when idling? Terruko Issues | Warranty | Recalls / TSB 29 10-16-2016 08:09 PM
6 speed m/t idling low Gt86_nick Engine, Exhaust, Transmission 1 01-28-2014 08:54 PM
Idling Issue ericmpena Issues | Warranty | Recalls / TSB 1 11-01-2013 01:21 AM
High idling on new FR-S ndsleep612 Issues | Warranty | Recalls / TSB 19 07-27-2013 11:06 AM
Idling/RPM question Crackseed Hawaii 3 02-25-2013 12:54 AM
