Old 07-09-2018, 09:17 AM   #1
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
slotted upper strut bolt hole. KW x GReddy
I have already sent KW an E-Mail asking what their official response is but I have not yet received a reply. I expect to hear back within a day or two.
I have not found mention of how KW intends for this slotted upper hole to be used. NORMALLY you'd have an insert locking everything in place. Something like a 0* insert and then a 2.5* or something like that. Am I missing pieces or am I supposed to rely on clamping force to hold it in position? I know people do this on stock stuff to gain more camber but that has always seemed sketchy to me.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 07-09-2018, 09:29 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Stock bolt and torque to spec. I haven't had issues with this slipping on my RCE coilovers.
Old 07-09-2018, 09:31 AM   #3
Roadcone
StreetKart
the stock bolt isnt oval. what is the range of movement here?
Old 07-09-2018, 12:42 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
That "NORMALLY" of inserts of preset camber and to prevent slippage is common for rally coilovers (another example and another). IIRC there was mention of such for eg. MCS coilovers, for STX rule compatibility or smth. like that. But Normally even if slot hole is slotted for camber adjustment on aftermarket coilover, maker doesn't also offer inserts too. One should put (non camberbolt) bolt there at rough position one needs, tighten, and fine-adjust camber using other hole. Works for most, if not receiving heavy hits to suspension.
Old 07-10-2018, 09:35 AM   #5
Roadcone
StreetKart
just seems super janky to me to just hope its where you want it lol
Old 07-10-2018, 11:42 AM   #6
AFRichZC6
AFRichZC6's Avatar
It's not janky. That's normal for most struts. Clamping force is what primarily holds the spindle and strut together in the same position, and the amount of load you see on the street or track shouldn't cause the hardware to slip, if they are torqued correctly.
The machined inserts in MCS (and also AST/Moton) struts are just like a back-up in case it slips under extremely high load. You still don't want to rely on the bolt shank itself to take the load - shear load is not where it is strongest.
AFRichZC6 is offline   Reply With Quote
The Following 2 Users Say Thank You to AFRichZC6 For This Useful Post:
driggity (07-10-2018), strat61caster (07-10-2018)
FS: STI Group N Front Upper Strut Mounts 200hp/tonne Brakes, Suspension, Chassis 0 07-01-2017 04:12 PM
WARNING: DO NOT use 14mm OEM camber bolt in slotted hole switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 10-31-2014 04:56 PM
Whiteline KCA416 or Crash Bolt for slotted upper strut? FR-S Matt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-31-2014 04:10 PM
slotted upper strut hole hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-22-2013 11:31 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
