Old 07-08-2018, 01:48 PM   #1
Geese1
Geese1's Avatar
Drives: 2018 BRZ w/ PP - WRB
Traction control and ABS light on after LCA install
Just installed some SPC lower control arms today, and while the install seemed to go off without a hitch, now my traction control (car with wavy lines underneath) and aBS lights are on.
I tried using my OpenFlash tablet to see if there were any ECU codes, but it came back saying there were no codes present.
Not sure if they're just on because the alignment is way off, or if there's some other issue. I have an appointment to get an alignment tomorrow, so if that's all it is, it would be great.
In the meantime, any ideas on how I can solve this?
Geese1 is offline   Reply With Quote
Old 07-08-2018, 02:23 PM   #2
Did you remove the wheel speed sensors before you pulled the axles out of the hubs?
If not, they are toast. The magnetic disks on the axles will also be bent. Look for the service manuals in my sig line.
Old 07-08-2018, 03:53 PM   #3
Geese1
Geese1's Avatar
Nothing I read/watched said anything about removing wheel speed sensors. Just had to unbolt the 5 bolts (4 on the one side) for the hub, shock, endlink, and attachment point (and the headlight leveler on the one side). Then simply swap in the new lower control arm and reattach the bolts (and use the new bolts for the hub assembly).
This is the main video I used:
[ame="https://www.youtube.com/watch?v=ziMhyGgr7tE&index=2&list=PL_h3HQ482-IgYhKK5AmOuYerTqfZ5WZQ5&t=0s"]https://www.youtube.com/watch?v=ziMhyGgr7tE&index=2&list=PL_h3HQ482-IgYhKK5AmOuYerTqfZ5WZQ5&t=0s[/ame]
I watched several other videos, and they all basically followed the same template. None of them even mentioned the wheel speed sensor.
Old 07-08-2018, 04:17 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your alignment is way off.
Old 07-08-2018, 04:19 PM   #5
Geese1
Geese1's Avatar
Hopefully that's all it is. I've been doing a little research, and apparently the alignment being off can trigger these two warning lights.
As I said, I've got an appointment at 8:00 a.m. tomorrow morning to have an alignment done, so keeping my fingers crossed that will fix the issue.
Old 07-08-2018, 04:29 PM   #6
Yeah. I'm an idiot. You don't have to move the carrier for those. NVM.
Old 07-09-2018, 12:00 PM   #7
Geese1
Geese1's Avatar
Had the alignment done this morning and that took care of the issues. Didn't realize until I was driving up to the shop how bad the alignment was - steering wheel was pretty heavily off-center. The shop actually recorded a steering wheel angle error in the ECU before they did the alignment. Not sure why the OpenFlash tablet didn't show the error code on their end when I checked yesterday.
Either way, it's all set now and she's handling great again!
Old 07-09-2018, 02:03 PM   #8
I suggest zeroing out the VSC system. Should be the minimum labor charge at the dealer. All they have to do is plug in and click a couple buttons.
Old 10-01-2024, 10:54 AM   #9
B00STED86
Drives:
I have a similar issue and I’ve seen you talk about it a few times during my research. So I installed the fdf mega mantis kit and a hydraulic hand brake at the same time on my 13 Brz. I now have the traction control light on and abs light which Is probably normal after doing such modifications. I tired zeroing out the vsc with techstream and I keep getting a communication error. I’ve used techstream before to program my vin on my ecu without issue. Any idea on how to get around this problem?
Also when I press the vsc button or switch on the pedal dance feature on my trac box, nothing happens. Do I still need to use the trac box or an aids disabled from removing the abs? It seems like I still have traction when trying to brake loose. I’m getting mixed or vague info when researching.. I’ll post the error I’m getting. My scanner isn’t picking up codes, but techstream has a few and I will post them, TIA
B00STED86 is offline   Reply With Quote
Old 10-01-2024, 10:55 AM   #10
B00STED86
Drives:
Codes and then I get a another connection error
Old 10-01-2024, 01:06 PM   #11
Those errors all point to the ABS module. That's where all the smarts for VSC live - accelerometers (rate sensors), pressure sensors, and all the processing. Is it properly connected? Damaged?
Old 10-02-2024, 01:12 AM   #12
B00STED86
Drives:
So when I installed the handbrake, I deleted the abs unit. But kept all the electronics plugged in and capped of the open side with a piece of aluminum.
Old 10-02-2024, 01:55 AM   #13
If I was a betting man...
Old 10-06-2024, 08:53 PM   #14
B00STED86
Drives:
When the abs is removed, is traction control also deleted?
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 09:00 PM
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 09:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
ABS and Traction Control Light on -> ABS Actuator Went Out N1rve Issues | Warranty | Recalls / TSB 11 11-29-2015 08:35 PM
ABS, Traction control and brake light??? JMoore412 Issues | Warranty | Recalls / TSB 18 08-20-2014 05:09 PM
