Old 06-30-2018, 10:55 PM   #43
Wow! And then it's programmed to keep cranking until either RPM goes above threshold value, or until it times out. No in-between.
I really don't like that. I guess if I was forced to use that circuit, I'd move the clutch interlock to another position on the dash so I'd have to use both hands to crank. ...maybe.
Ultramaroon - back in the day -
Old 06-30-2018, 11:08 PM   #44
Um, no. Unless you enjoy sprained wrists, pull up.
Old 07-01-2018, 01:15 AM   #45
Easy for you to say, you were big and heavy; I was small and light, I had to jump off a 5 gallon bucket onto the crank handle ..
Ultramaroon (07-01-2018)
Old 07-01-2018, 03:07 AM   #46
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by Coop View Post
Because the brake fluid doesn't compress and air does. Pretty much when I pushed my clutch all the way in it would actually not be separating the clutch from the fly wheel all the way, just partially. And I think there is a sensor in the actual clutch that can tell if it is separated or not.
I don't think theres a sensor in the clutch itself o_O
That’s what I think because if you depress the clutch and push, you immediately crank. In order to get to ACC and ON, you need to not depress the pedal (all which is info passed to the ECU via the switch)
This is true. Realized this the other day too, kind of a PITA. I'd have to make my own little toggle switch if I ever wanted to get into ACC mode again.
Anyway, drove my car around today and had no issues starting it. The valets at my garage also havent complained about having issues starting it either, its a freaking mystery. Gonna be driving around some more tomorrow.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Sportsguy83 (07-01-2018)
Old 07-03-2018, 02:25 AM   #47
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
I just had this problem, its an easy fix but it'll be uncomfortable. If you look underneath where your clutch is. At the very top where the clutch pivots there is a small pin switch. When you step on the clutch, a little metal plate presses down on the switch and the car cranks up. I was able to turn on the car just by pressing on that pin with my finger w/out touching the clutch. Its hard to see and you need to crawl on your back. The sensor is mounted to a flat plate that has two 14mm bolts on each side, i just took a small 14mm wrench and loosend it up a but, which moved the sensor out a bit. So now when I step on the clutch that little pin gets fully pressed and starts every time now. Sorry I couldn't get a better picture.
Sent from my SM-G935T using Tapatalk
BlOody_BoOger is offline   Reply With Quote
The Following 2 Users Say Thank You to BlOody_BoOger For This Useful Post:
humfrz (07-03-2018), RL_BRZ (07-03-2018)
Old 07-03-2018, 12:13 PM   #48
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
But you can keep it cranking forever too by keeping the button pressed
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Ultramaroon (07-03-2018)
Old 03-18-2019, 06:24 PM   #49
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
I think this thread is going to save me a lot of future frustration! I've had this intermittent starting issue and ruled out the battery, starter, fuses, and an incorrectly-diagnosed wheel lock preventing the car from starting. I intuitively suspected there was some kind of electrical mechanism with the clutch preventing the car from starting. Ordering this now! Hopefully it's not too much of a pain to swap out.
Beachin86 is offline   Reply With Quote
The Following User Says Thank You to Beachin86 For This Useful Post:
Vesartis (02-29-2020)
Old 08-10-2019, 10:56 AM   #50
RocknTommy
Just completed mine. Tip, tighten till there is about 4 or 5 threads showing where the nut is by the switch. That video did really help especially the tip of using pliers to hold the switch when wrenching.
RocknTommy is offline   Reply With Quote
The Following User Says Thank You to RocknTommy For This Useful Post:
enderw88 (08-10-2019)
Old 08-10-2019, 12:13 PM   #51
enderw88
Drives: 2015 BRZ WR Blue Series.Blue
Thanks for pointing to that video. I have exactly those symptoms.
2015 BRZ Series.Blue
2006 Moto Guzzi V11 Sport Laverda
1976 Yamaha RD400 TZ
enderw88 is offline   Reply With Quote
Old 03-25-2022, 12:55 AM   #52
Kaotic Lazagna
Drives: GR Corolla
Bumping this thread since I was just experiencing this issue. Only thing I was able to do atm was wipe down the two plungers on the switches, and it seems to have solved the issue.
I will be ordering a new clutch start switch tho.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Ultramaroon (03-25-2022)
Old 03-25-2022, 01:34 AM   #53
BlOody_BoOger
Save the money just wrap the part that makes contact with the switch with some electrical tape thick enough to make better contact when you have the foot on the clutch that fixed mine.
Sent from my IN2017 using Tapatalk
Old 03-25-2022, 02:25 AM   #54
Kaotic Lazagna
Drives: GR Corolla
Is that the issue? I assumed that debris collected on the plunger to the point where it doesn't go in correctly or enough.
Old 03-25-2022, 03:49 AM   #55
BlOody_BoOger
Atleast for me it was, lol for some time I used it as a kill switch haha only cuz I was able to reach the switch from a seating position so I would hop in the car reach down hold the switch(car in neutral) and start it up.
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 08:06 PM
Clutch Switch Bypass OmarGC Engine, Exhaust, Transmission 20 01-01-2015 10:41 PM
Swapping out exhaust tips, bolts broke off!!!! Help! BBYZILA Cosmetic Modification (Interior/Exterior/Lighting) 7 12-19-2014 08:04 PM
Start Stop Switch - BRZ Limited whatsinaname BRZ First-Gen (2012+) — General Topics 7 05-18-2014 10:30 PM
Push-button start clutch switch mike the snake Engine, Exhaust, Transmission 8 04-15-2014 12:31 AM
