#15 | |
Drives: Boosted
Long story short, fully let go of clutch before use of gas and don't use the gas to slip the clutch even if it makes it more smooth. This is one of those times where I'd wish my clutch wasn't so soft lol. So as long as I don't glaze the clutch i.e hold it at the friction point for 2-3 seconds I should be fine? |
#16 | |
But it is a consumable. Just use it for it's intended purpose and enjoy exploring the limits. You'll feel it get hot way before you smell it. If it gets mushy on engagement, it's too fucking hot.
#17 | |
Drives: Boosted
#18 | |
#19 |
I hear that some can be tricky to modulate and prone to chatter. Chatter is awful for this transmission in particular.
#20 | |
The Dictater
Drives: '13 Red Scion FRS
Just to clarify... Use the bolded technique only when shifting. The clutch is designed to slip on startup from a stop. It's fine (and recommended) to modulate to clutch when you start the car moving as long as you apply a low amount of power until the clutch hooks up. Might be obvious, but had to make that clarification just in case. |
#21 | |
Drives: Boosted
#22 |
@incutebus
push clutch in start car put in gear let clutch out and press on gas ….. (both at once) drive car press in clutch let off gas (both at once) take car out of gear just do all of the above, in that order, without thinking about it ….. ![]() Now, if you come back before you practice that ……. I'm ah gonna hafta ya. humfrz |
#23 | |
Drives: Boosted
#24 | |
It doesn't look that hard. It would be easy for me …. just drive up to the local auto shop, tell the guys to take out the CDV and be sure to bleed the system. Have a cup of coffee and a smoke, tell a couple of back-in-the-day stories, pay them, drive home and take a nap. ![]() humfrz |
#25 |
Drives: Boosted
Guess deleting my cdv did it 👌👌👌
| Brake and Clutch fluid questions | ducky106 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 03-04-2019 08:58 AM |
| I keep breaking lug studs!!! | Guff | Issues | Warranty | Recalls / TSB | 59 | 12-30-2015 12:34 AM |
| Clutch install questions | wootwoot | Engine, Exhaust, Transmission | 25 | 12-29-2014 04:18 PM |
| Breaking-Bad SWP Build | mwjcyber | Member's Car Journals | 7 | 02-17-2014 08:12 PM |
| exedy clutch questions | ft86me | Engine, Exhaust, Transmission | 8 | 02-13-2014 09:58 PM |
