Old 01-15-2018, 01:13 PM   #155
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by justinco View Post
Right at the time that I linked. I weighed both exhaust parts right before that.
Oh, I see now. I clicked "play" on the embedded video and it started from the beginning.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 01-15-2018, 01:58 PM   #156
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yea weird, I noticed that too. In my quote it showed the starting time point, but the reply linked the start of the video.
justinco is offline   Reply With Quote
Old 03-08-2018, 06:31 PM   #157
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
My ACE A-350 header was 9.5lbs, not including the overpipe.
The Following 2 Users Say Thank You to justinco For This Useful Post:
new2subaru (03-08-2018), Tristor (05-29-2018)
Old 03-09-2018, 08:15 AM   #158
new2subaru
Weight Weenie
Drives: 15 FR-S
So, it's the lightest on the market according to the original list
You didn't happen to weigh the overpipe did you?
Old 03-09-2018, 12:52 PM   #159
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I did, but I did not write it down or remember.
It was a smidge lighter than my Perrin overpipe, so it should be right around 3 to 3.5lbs.
The Following User Says Thank You to justinco For This Useful Post:
Old 03-09-2018, 06:31 PM   #160
new2subaru
Weight Weenie
Drives: 15 FR-S
Cool, thanks.
Old 03-09-2018, 07:42 PM   #161
cjd
cjd's Avatar
Drives: 2017 BRZ
I intend to weigh as I install so should have numbers on the full Ace 350. It's light. Will only have to the nearest lb though.
The Following 2 Users Say Thank You to cjd For This Useful Post:
new2subaru (03-11-2018), Tristor (05-29-2018)
Old 06-04-2018, 09:34 PM   #162
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I got the Dezod Motorsports dual exit exhaust. It weighed in at 34lbs total on my scale.
Muffler section: 19lbs
Connecting pipe section: 3.82lbs
Mid-pipe section: 11lbs
They advertise 29.2lbs, so either my scales are not that accurate or it isn't under 30lbs.
http://www.dezod.com/dezod-motorspor...i-2119546.aspx
botbs (06-24-2018), SuperTom (06-04-2018)
Old 06-06-2018, 11:14 PM   #163
cjd
cjd's Avatar
Drives: 2017 BRZ
Dang - same thing with Thermal, though they don't list the weight; I emailed to ask, and someone went and weighed it for me since they had some out. Said 29.5lbs - came in at 37lbs when I weighed it. I didn't weigh the pieces, but I believe I left one section off the scale at a time and still could not not find ~30lbs.
I like the noise level though, they nailed the resonator. Highway cruise, even with the rear seats down, road noise from the tires (Michelin PSS) and wind noise were the loudest things. Gets a bit brassy higher RPM from behind the car, almost like there's a rattle, but that may just be how the system is going to sound with this header.
I also totally forgot to weigh the Ace 350.
The search for a light-weight and quiet exhaust may simply not be realistic without quite deep pockets. I'll take the money in my pockets and some extra weight for now.
Old 06-08-2018, 02:38 PM   #164
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You can build one for pretty cheap. The custom setup I have been using for the past 1.5 years (between all the other exhausts) was 26lbs and plenty quiet enough. It just did not fit well (banged up against the tunnel) and was not pretty lol. I think the key (to keeping sound down) is an OEM resonator. All of these aftermarket ones come with tiny resonators...well, except the Blitz VSR I had, that one was huge.
Old 06-08-2018, 03:06 PM   #165
cjd
cjd's Avatar
Drives: 2017 BRZ
I don't have the OE resonator in the midpipe, but it's a very large helmholz setup Thermal added. So not really contradictory, but not sure it has to be OE.
I was including 'nice looking and without odd buzzes and rattles' in my list of requirements. Also maybe not making a parachute of the rear bumper.
If I were competitive and thought 10lbs mattered that much that's a different story. Hope the Dezod works out for you though!
Old 06-08-2018, 03:18 PM   #166
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I guess large resonator is more appropriate, doesn't have to be OEM, just OEM sized.
While I love maximizing the setup for weight savings, I think I am done and will live the smidge extra weight. There is improvement in my driving that will save more time than an extra 8-10lbs weight savings will.
cjd (06-08-2018), strat61caster (06-08-2018)
Old 07-29-2018, 12:54 PM   #167
Bykov
Drives: 2014 Monogram FR-S Whiteout
Open flash header V3 broken down:
Header: 10lb 6.1 oz
Overpipe: 2lb 15.0oz
Clamp: 5.2oz
Header ID 60mm
Header runners ID 44.45mm
op outlet ID 63.5mm
The overpipe has a slip fit and clamp setup to the header and that’s where it steps up to 2.5inch ID. The fit and finish is really damn impressive and the weight is as well for the quality of this piece. Taking my V1 off soon and will get weights and measurements for that as well.
Bykov is offline   Reply With Quote
The Following User Says Thank You to Bykov For This Useful Post:
SuperTom (07-29-2018)
Old 07-29-2018, 03:46 PM   #168
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I wish Anthony would update the First Post as we add too it. All my weights include any clamps & hardware
To confirm Justinco's weight on the Ace 350
Ace 350 Header = 9.75lbs
Ace Overpipe = 3.5lbs
Also
Hooker Header Blackheart Catted Resonated FP = 9.5lbs
Borla Full Catback (forgot to tare plate in pic) = 29.25lbs
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
new2subaru (07-29-2018), Tristor (07-30-2018)
Borla UEL headers + HKS Front pipe + Greddy SP AxleBack = music sounds to my ears. NoFear99 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 09-23-2013 12:02 AM
FS: OEM Exhaust and Mid and front pipe Bcarlos Engine, Exhaust, Bolt-Ons 3 07-24-2013 06:16 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 05:16 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 01:29 PM
