Old 05-27-2018, 03:14 AM   #1
Sikku
Drives: SWP 13' BRZ
Rear Endlink Bolt
Hey guys! I recently installed coilovers on my car. Unfortunately I lost the rear endlink bolt I found the part number which is 901000360. Does anyone know the bolt size of this part? I am trying to go to my local hardware store instead of traveling a bit to my Subaru dealer for just a bolt. Thanks!
Sikku is offline   Reply With Quote
Old 05-27-2018, 02:24 PM   #2
norcalpb
norcalpb's Avatar
I think it’s a 14mm socket that’s used so just see what head size the 14 slips over (m10,11 or 22)
Old 05-27-2018, 11:25 PM   #3
Vten
Drives: Too heavy
Yup 14mm for bolt and nuts. Installed the Perrin swaybar earlier today and had to take off those sway link off the lca.
Vten is offline   Reply With Quote
Old 05-28-2018, 09:41 AM   #4
mnuttall
Drives: 2013 Audi Allroad, 2017 Subaru BRZ
I think it's an M10x80mm flanged bolt. Don't know what grade it is though.
mnuttall is offline   Reply With Quote
Old 05-28-2018, 02:07 PM   #5
norcalpb
norcalpb's Avatar
Bolts from the hardware store that get used on the suspension should be grade 8
Old 05-28-2018, 02:59 PM   #6
mnuttall
Be careful with that. A metric Grade 10.9 will be roughly equivalent to US Grade 8.
The Following 2 Users Say Thank You to mnuttall For This Useful Post:
RedReplicant (11-23-2022), wparsons (05-28-2018)
Old 05-28-2018, 03:45 PM   #7
Vten
Drives: Too heavy
Here’s what I got today, one of the oem bolt was stripped and I had to run to Home Depot to get a temporary replacement. The bolt size is. 3/8 and about 3” long.
I was in a hurry and got the 3/8x4” one and yes it’s 1” longer, but it’ll be temporary as my Perrin fixed sway link will be here Thursday that includes some new bolts n nuts.
The Hope depot one using the same 14mm head as oem.
Old 05-29-2018, 05:40 AM   #8
Sikku
Drives: SWP 13' BRZ
Thanks guys. You guys are amazing! Appreciate all of the responses
Endlink bolt issue oppiee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-15-2018 10:24 PM
Rear lower control arm endlink/shocks ratio adjustments Brzerker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-05-2018 01:05 AM
Safe to drive with 17mm endlink/strut bolt not fully tight? kev60625 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-17-2016 04:23 AM
OEM Rear LCA Bolt Specs Philly758 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-29-2014 09:34 AM
Camber bolt for the rear ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2013 02:49 PM
