Old 05-20-2018, 08:49 PM   #1
Rawr_86
Rawr_86's Avatar
Wheel/Tire/Suspension help
Hello!
I just picked up wheels that are 18x9 et 45.. and wondering what size tires you guys reccomend? Also, I am planning on lowering it, what size drop would work without rubbing? Thanks in advance for the help! I’m new at this haha
Rawr_86 is offline   Reply With Quote
Old 05-20-2018, 09:39 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Rawr_86 View Post
Hello!
18X9 +45 is right at the max width for springs. It either will rub on the spring perch or need a 3-5mm spacer in the front. It will fit in the back. Coils will fix this issue in the front, as the coil's springs have a smaller diameter than stock.
225/40 is a good size, if you get 1" drop springs or less, and run a spacer in the front.
245/35 will work if you get coilovers and have a way to adjust camber front and rear, like lca, camber bolts and/or some coils have camber adjustment in the tophat, some re-use the stpock tophats with no adjustment. read through this thread. find similar setups and compare their list of suspension mods.
https://www.ft86club.com/forums/showthread.php?t=7535
I LIKE TIRES!
Old 05-20-2018, 11:42 PM   #3
Rawr_86
Rawr_86's Avatar
Thank you for your help! I appreciate it!
Old 05-21-2018, 02:04 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
You still should have:
1) state your goals / expectations / wishes, so that recommendations can be given based on those
2) inquire nfo / ask questions before any purchase (including wheels you rushed to get)
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 05:25 PM
Wheel and tire specs for FRS (New Tein Flex Z suspension installed) c0nnexi0n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-18-2017 08:58 PM
Wheel/tire/suspension question ARTBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-15-2015 08:58 PM
Highest lateral G force grip after wheel / tire / suspension? iBoost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-29-2015 10:54 AM
Wheel gap - from suspension height or tire diameter? CaptainSlow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-27-2013 01:48 PM
