#15 | |
Compare base model vs PP, as you do need to factor in BTM trim. |
#16 | |
Drives: '05 Elise
My Miata isn't exactly track prepped (it's an autox STR build), and doesn't even have a roll bar, but I took it out at PittRace during a track night in America event before the '18 SCCA Match Tour and the non-brembo base brakes did just fine (with pads and fluid swap.)
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
#17 | |
The PP itself is totally worth it, but not worth it when you also have to get the limited trim, IMO. |
#18 |
Drives: 2013 Firestorm FR-S
Sounds like a '13 car with a '17+ engine is an economical way to go if you feel like doing the swap.
#19 |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#20 |
Other than the engine and accompanying ECU what's the difference?
#22 |
#23 | |
Drives: '23 BRZ
If I didn't want leather, I probably would have gotten a used FR-S...
| The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (05-14-2018) |
#24 |
The Fail Boat
Drives: CWP S.B.
It's definitely a luck issue, go with 17+ if you are worried, from 17+ onward they shot peening the cylinder wall & the cam gears alone with some added reinforcement on the rear of the block or somthing. can someone varify?
#25 |
JHerbert Racing
Drives: 2013 Scion FRS
I have had great luck with my 2013 with around 15k track miles on it. However, if I could swap it out for a 2017, I would. Unless you can get a KILLER deal on a perfect 2013-16, buy a 2017.
| Is buying a used brz more beneficial then buying a new one? | Jcas | BRZ First-Gen (2012+) — General Topics | 60 | 10-20-2017 12:15 AM |
| MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 01:39 PM |
| buying salvage twin for track worth it? | WATCHMEHEAL | Tracking / Autocross / HPDE / Drifting | 15 | 09-03-2013 02:31 PM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-20-2012 11:31 PM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | Tracking / Autocross / HPDE / Drifting | 0 | 08-14-2012 06:46 PM |
