Old 05-05-2018, 09:56 PM   #365
steve99
Drives: FT86
Originally Posted by SkyeHack View Post
I just got an OFT 2.0 for my 2018 tS. However, I do not see a calibration file for my car from the website.
"ZA1JN10C"
How can I get a OTS tune that is compatible for my 2018 tS?
As its a very new calid you will need to contact oft guys for them to make tunes for that calid
SkyeHack (05-05-2018)
Old 05-05-2018, 10:15 PM   #366
BushidoSpirit
BushidoSpirit's Avatar
Drives: 2016 Halo FR-S, 1982 VW Rabbit
Not sure if I did something wrong, but I loaded up the v4 tune into RomRaider, along with the correct definitions pertaining to my CAL ID (that came in the ZIP file) I see some weird numbers that don't really make sense in the axis for the Base Timing Idle (In-Gear) map. Any ideas what could be wrong?
BushidoSpirit is offline   Reply With Quote
Old 05-06-2018, 04:02 AM   #367
tomm.brz
Drives: brz 2017 hksv2
use definition steve posted in first post, they are better
BushidoSpirit (05-06-2018)
Old 05-06-2018, 05:44 AM   #368
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You have a B01C based F40C definition in the list before the most recent A01G based one you added.
The Following User Says Thank You to Wayno For This Useful Post:
Old 05-06-2018, 08:06 AM   #369
BushidoSpirit
Thought I already edited the XML with the correct CAL ID, guess I didn't lol. Edited, reloaded, and all is good now. Thanks!
I didn't have any previous definitions in RomRaider, if that's what you mean. Removed everything, and just used what was in the V4 zip files. In any case, using the first post and changing the CAL ID worked like a charm. Thanks for the help!
Old 05-06-2018, 09:03 AM   #370
tomm.brz
yes i noticed too the definitions shiv put in the v4 package have some maps broken.
Bin them :') and only use steve's
Old 05-06-2018, 04:27 PM   #371
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
are you using the definitions steve posted in first post?
you find the two maf corrrection after start in the mass airflow section
in v4 the first 2 rows are same as the other rows..from 8 to 4
you want maybe to start 15 and finish with 5 or 6
then maybe do a blend with stock values in idle tables to rise it a bit.. the higher the idle speed is, the louder it will be
When I try to use steves definitions i get "ecu definition not found" error. My cal ID is D00C MT. I have also cleared out the previous v4 def.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 05-06-2018, 04:52 PM   #372
elBarto
elBarto's Avatar
Drives: Toyota GT86
I've posted a D00C def somewhere in this (or the popcorn) topic.
edit:
Found it:
D00C XML
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
FT86Z (05-06-2018)
Old 05-06-2018, 06:21 PM   #373
tomm.brz
open the "base is a00g" def with notepad and modify the first 2 cal ids you find to za1jd00c
FT86Z (05-06-2018)
Old 05-06-2018, 07:04 PM   #374
sIowbrz
Drives: 2015 brz
https://datazap.me/u/carewyip/log-15...7-8-9-10-11-13
https://datazap.me/u/carewyip/log-15...5-7-9-10-11-13
can someone take a look of these 2 log for me see if im safe or need to worry about anything thx
sIowbrz is offline   Reply With Quote
Old 05-07-2018, 04:59 AM   #375
Hella Basa
Hella Basa's Avatar
Drives: 2014 Subaru Brz Limited
if you only change ignition timing post start, will be louder but not like stock
stock cold start is very loud also because has higher idle so if you want it loud rise it like at 1400 rpm minimum, on the "left" zones of the idle maps
v4 tunes has max of 1200rpm that s not much to get it loud
but yes, it s basically only that, try put -15 or -19 (this one is on my17+ stock rom) and hear it
but v4 has maf correction after start a lot reduced on cold start, you should put higher values on the first 2 rows in those 2 maps, but v4 oft definitions have them not defined, you need better definitions to modify them
up to what temperature do I change the .04 to -15?
Hella Basa is offline   Reply With Quote
Old 05-07-2018, 05:13 AM   #376
tomm.brz
easiest way is to change all the values to -15
Old 05-07-2018, 04:41 PM   #377
FT86Z
Drift noob
FT86Z's Avatar
The cold start is much louder now thank you guys for the guidance. Only thing is the brief dip to 500 rpm before it shoots back up to 1400. Can't figure it out for the life of me
FT86Z
藤原とうふ店
Old 05-07-2018, 05:12 PM   #378
tomm.brz
The dip is normal, It does It when the cold start phase is over and the timing pass from -15 in your case to normal idle timing of about +10..
Actually it does another One when the oil is at a good temperature and the vvt activates
So don t worry
FT86Z (05-07-2018)
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
