Reckless5.86
Drives: 2013 Scion FRS
Parking brake light probelm and check engine problem
Hey everyone, so over the past couple of weeks I’ve started to notice that every so often my e brake light will go on without it being up and while I’m driving. Mainly when turning. Any ideas on why this happens. Also, I don’t know if this is the right section. But when I get very low on gas. My check engine light will go on. But will go off after I fill up and turn the car off. Any idea as to what that could be as well. Thanks everyone
#2 | |
Country Boy 4 Life
I LIKE TIRES! |
#3 |
Reckless5.86
Was in a slight fender bender a while ago. Was professionally fixed. 50k miles. Cat back exhaust. And 2nd owner. I’ve owned the car for 5k miles and has never occurred previously
#4 | |
Oh, yes, if it continues to become low, you might want to look for a leak. As far as the CEL and low fuel, the next time it happens you may wish to read (or have read) and code that is given (if any). If you don't get a code, I wouldn't worry about it. humfrz |
#5 | |
Reckless5.86
#6 | |
![]() That way you can check for (and erase) codes anywhere you are. Yep, for $30-$50. they are a handy tool to have in your trunk. humfrz |
#7 |
Reckless5.86
#8 |
| The Following User Says Thank You to humfrz For This Useful Post: | CSkap21 (03-09-2018) |
#9 |
Drives: FT86
Just be aware oft only read/clear engine eCU related codes.
they wont show codes from other control modules in car like ABS VSC Auto Trans dash ect |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | CSkap21 (03-09-2018), gravitylover (03-09-2018) |
#10 |
The light doesn't have to be on for them to read what codes were thrown. They can do it anytime.
| The Following User Says Thank You to Tcoat For This Useful Post: | CSkap21 (03-09-2018) |
#11 |
Reckless5.86
Thanks everyone
#12 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
I have to offer a different spin on this. Your brake fluid may indeed be low for the light to be occasionally coming on. The reason your fluid may be low is that the brakes may be low and in need of replacement (should be in the owner's manual). You should not be losing any fluid unless there is a leak in your system, so as the brakes wear out, the fluid level drops. When it gets to a certain low point, that would mean your pads are at or near the point of replacement. Have you done your brakes recently? Ever? Anyway, if you just top off the fluid level, you won't get another warning when your brake pads are totally worn out, you'll find out the hard way when you get metal on metal.
Have a look at your brake pads before you go adding any fluid.
-O/D
2016 FR-S, Hot Lava |
| The Following 4 Users Say Thank You to Overdrive For This Useful Post: |
#13 |
^^This is exactly what I was going to say. I 'topped off' the fluid in my car at one point and then when I changed the rear pads and rotors drove about 40 miles at highway speed and all of a sudden the rear brakes nearly locked up. As the overfilled fluid heated up it pushed the pads in and ruined my day at 4am when I saw smoke pouring out of my car in the rearview mirror. I didn't realize what it was or I could have solved it quickly but instead sat there waiting for a shop to open in that town.
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| Parking brake lead problem? | BRZ'13 | Issues | Warranty | Recalls / TSB | 7 | 07-28-2014 01:42 PM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
