| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#211 | |
Drives: none
#212 |
Drives: Scion FR-S Raven
I'm hearing this noise for sure and it is embarrassing.
#213 |
Drives: Supercharged Golf Cart
#214 |
Drives: 2013 BRZ, 2002 WRX
I will track down the brand name guys. It was something like Resitol or something like that. Damn it, I knew I should have written it down. Give me a few...
#215 | |
Drives: Skoda Yeti DSG diesel 4x4
Plenty of people have been doing it for years, in diesels and gasoline engines for its benefits. Why would you use some upper cylinder additive instead? I use Valvoline Racing 2 stroke oil. Try it when the tank's low, wash it in with some fuel. That way you can fill up and dilute it if you are still in a quandry. |
#216 | |
Simple problem, simple temporary fix until they use a teflon coated washer or something in the pump. http://www.underhoodservice.com/issu...ontentid=65858 |
#217 | |
Rislone Injector Cleaner To be clear, I mixed 50ml of 2T oil (Lucas brand) in with the Rislone in the bottle. After reading the rest of the posts here, it seems that the 2T oil is probably what fixed the issue. I didn't feel like just pouring oil into the gas tank without first mixing it with something. If it comes back (and it probably will), I will try each individually. |
#218 |
I am going to order some Lucas Oil Upper Cylinder Lubricant/Cleaner, as well. Guess it's worth seeing what works best with the least amount of effort.
#219 |
Drives: '13 Ultramarine
Apparently crickets don't like ethanol
This could all be in my head, but I don't think so...
I have been using Ultra 94, which according to Petro Canada/Sunoco, can contain up to 10% ethanol. Yesterday coming back through town after a 100 mile drive, the cricket noise was quite loud. I could hear it while driving slowly through downtown (echoing off the buildings and parked cars...It's embarrassing). I managed to run the tank down to just less than 1/4. This morning on my way to work, I topped up with Shell V-Power 91 (no ethanol). When I got to work (a few miles through town), the crickets didn't seem as angry. I thought it must just be my imagination. After work, I drove around town for a while, looking for some German Castrol (found it at wally world). I got the car good and warm and can honestly say the cricket noise is almost gone. The clatter of DI is still there, but the "squeak" is MUCH improved. This could be wishful thinking on my part, but I think I may be on to something. For those with the cricket noise, are you using gas blended with ethanol? If so, try finding some premium that specifically says "no ethanol" on the pump. It may prove to be worth a try. As a sidenote, I spoke to a diesel mechanic today who has been at it for a long time. He suggested trying some LUCAS upper cylinder lubricant, adding that it is good pump lube, and he has seen it make a difference in pump/injector noise where people use low sulphur diesels when it is not required. I picked up a 5oz bottle today and will keep it in the car to try if the noise comes back. I will post up if anything changes, or if I fill with the 94 again and put the additive in as well. |
| The Following User Says Thank You to roddy For This Useful Post: | Bonburner (07-22-2012) |
#220 |
Drives: Scion FR-S
Yours must be fairly quiet. I can hear mine sitting in traffic on the freeway, windows up, AC on, with the radio on.
#221 |
Drives: Firestorm FR-S (MT)
#222 |
#223 |
Spaceman
Drives: 2013 Firestorm Scion FR-S
I know people keep pointing out that Toyobaru have acknowledged the sound and stated that it poses no threat to the mechanical well being of the vehicle. You guys can stop doing so.
Those of us that are concerned about this, at least myself, are no longer worried our engines are going to explode and simply want the horrible chirping coming from the engine bay of our BRAND NEW CARS to stop because many are OCD about sounds in their cars, others think it's embarrassing to pull up to a light in a car that many people notice and like to look at only to have their faces change to a befuddled look when they realize the car is making cricket sounds, and many more of us are worried about both. I think I'm going to go downstairs and mix a little 2 stroke oil with some gas and pour it into my tank.
#224 | |
Drives: Put Put
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
