| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 Hot Lava FRS
Accidentally tried lowering window while iced like an asshole, now doesn't work
As the title states, i tried lowering my window the other day and didn't realize it was stuck in place by ice. My window switches were flashing for a few days and the passenger side window won't move (even without the ice obviously). Is it likely I blew a fuse, if so, which one should I try replacing? Hoping I didn't mess up the regulator. Window currently stuck with about a half inch open.
ichi, feel free to move this if this is the wrong section. Wasn't too sure where to put this. |
#2 |
Little Member
Drives: Bloo - The 13' BRZ
There is an overload reset procedure in the manual, try this thread:
http://www.ft86club.com/forums/showthread.php?t=19731 Edit: I didn't read that they aren't moving at all, just saw the flashing part and assumed this reset. There should be a fuse box under the dash for the interior fuses and the legend on the cover.
| The Following User Says Thank You to yelsew For This Useful Post: | Slammillionaire (02-09-2018) |
#3 | |
Yeah my drivers side works fine it's just the passenger side |
#4 |
Drives: 2013 FR-S, 2016 Miata Club
You try this? http://www.ft86club.com/forums/showp...76&postcount=4
#5 |
Country Boy 4 Life
A few winters ago when I had this happen to my 2013 FR-S, it was snowing outside and there was a little bit of ice on my window. When I rolled down the window about 8 inches, it would not go back up. So, I put a down sleeping bag in the crack and a tarp over the window. I ran the car for about an hour with the heat blasting to warm the whole car up. It worked. The window rolled up.
Later, I read about holding the window switch for 10 seconds to reset it. And that worked too! ![]() Hope you get your window up.
I LIKE TIRES! |
#6 | |
I deal with iced up windows almost daily through the winter. Since getting my drive-through coffee each morning is a high priority in life I quickly learned how to deal with the problem. Each morning (almost all of them from December to March) I watch the window to see if it comes down when I open the door. If it doesn't then I scrape the window and take an old hotel door swipe card (any plastic card would do) and run it along the seal between the weather stripping and the glass. Sometimes I have to use some force and chip the ice out between the two but I have never had to reset the windows in 4 winters now.
| The Following User Says Thank You to Tcoat For This Useful Post: | JimmyMac (02-10-2018) |
#7 | |
| The Following User Says Thank You to JimmyMac For This Useful Post: | Tcoat (02-10-2018) |
#8 | |
#9 | |
#10 | |
#11 |
Drives: 2017 Toyota 86
Depends if he makes it at home it may require more time may not taste the same. Second he still has to go out to the car to get in and leave. I am not a fan of multiable trips so he may have to clear his drive way to get out plus warm the car up. I would think getting in and driving 1 min away would be easier and he would be on his way.
| The Following User Says Thank You to Zentec For This Useful Post: | Tcoat (02-10-2018) |
#12 | ||
#13 | |
The Dictater
Drives: '13 Red Scion FRS
#14 | |
Don't chop down against the seal. That would be bad and you could wreck it in no time. I can see how my original description reads like that though.
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (02-10-2018) |
| It doesn't work!! | Photomikes garage | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 03-06-2017 02:23 AM |
| Another Backup Cam Doesn't Work Thread | ChrisJ | Electronics | Audio | NAV | Infotainment | 5 | 07-01-2016 11:09 PM |
| Passenger window not going down (reset doesn't work) | ZionsWrath | BRZ First-Gen (2012+) — General Topics | 8 | 09-06-2014 12:19 AM |
| USB port doesn't work | brianc901 | Electronics | Audio | NAV | Infotainment | 2 | 08-15-2014 06:40 PM |
| Passenger Side Window Doesn't Work | JNovo79 | Issues | Warranty | Recalls / TSB | 5 | 02-18-2014 04:14 PM |
