Old 02-10-2018, 02:05 AM   #57
Except for cars in certain other countries ....then it can get confusing ...
Still a drivers side and a passenger side.
Old 02-10-2018, 02:22 AM   #58
Well, ya, but ..... but ...... it's not International.
Like right side and left side, if you're facing the ........oh, I see, unless your have dyslexia ...... or are a blonde.
Old 02-10-2018, 09:08 AM   #59
Riftur
Riftur's Avatar
Dont feel like reading the whole thing again. Did OP figure out what is not aligned properly?
Riftur is offline   Reply With Quote
Old 02-10-2018, 03:15 PM   #60
From the OP's other threads it looks like he was doing the work himself so odds are it has not been anyplace near a body alignment rack yet. Can align the wheels all they want it won't matter if there is some twist to the body. If the A pillar was bent as stated then there is very likely some twist someplace.
Riftur (02-10-2018), Summerwolf (02-10-2018)
Old 02-10-2018, 04:54 PM   #61
Brzlimited661
Drives: 2014 brz limited
Lowering the tire pressure helped some. Im really thinking its the tires.
Brzlimited661 is offline   Reply With Quote
The Following User Says Thank You to Brzlimited661 For This Useful Post:
Riftur (02-10-2018)
Old 02-10-2018, 05:04 PM   #62
Hey, stubborn one ...... ........ take your car here:
https://www.facebook.com/Bakersfield...2384752474766/
.......and buy 4 new tires and let them install them AND check the frame and suspension on your car and align it.
There ya go ....... problem solved .......
Old 02-10-2018, 05:28 PM   #63
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Have you done any measurements or inspected the subframe or anything?
Old 02-10-2018, 05:46 PM   #64
Brzlimited661
Im not qualified to do that most likely ill just wait and change the tires anyway if that doesn't work then ill go from there. Just to clarity just the alignment numbers i provided wouldn't cause the car to behave like this right? Not talking about frame measurements but alignment measurements. If the cars frame was intact would my alignment numbers cause whay im experiencing.
Old 02-10-2018, 06:50 PM   #65
You could have perfect alignment numbers on the suspension and the car would still act that way if the frame specs are off by even a little. This has be explained several times. Charging tires and aligning suspension may mask it for a bit but it will happen again. Get it checked before the car get totaled a second time. You are not saving any money by throwing parts at it in the hopes it is something else.
humfrz (02-10-2018), Spuds (02-10-2018)
Old 02-10-2018, 07:50 PM   #66
Summerwolf
Panda Trueno
Summerwolf's Avatar
I explained the caster issue pages ago. It's differing by over a degree side to side.
New tires alone probably won't be your fix. Jack the car up, visually inspect for anything bent, pop your hood and check the strut towers.
Throwing money and parts at the vehicle until you fix it is more hassle then just figuring out the problem and the correct fix. I think a body shop will check the vehicle on a frame rack for less than a new set of decent tires.
The Following User Says Thank You to Summerwolf For This Useful Post:
Spuds (02-10-2018)
Old 02-10-2018, 11:01 PM   #67
Dake
Dake's Avatar
Thought I'd throw this out since it's in a similar vein. Just in the last couple months, I've started having the Traction Control kick on during sweeping, high speed curves like entrance or exit ramps. It has never done this before.
It's not an actual loss of traction, it's like something in the rear grabs. It doesn't feel like a brake though (which it should be doing all the time if that's the case, and there's no burnt brake smell), and it's under steady power or even coasting - but not lift-off in the corner, more like off the gas before entering. I have new tires (it was doing it before and after tires). I also just had an alignment done which appeared to help a bit. Before it happened in the forties, now it happens in the fifties. Otherwise, the car continues to drive straight, doesn't pull, no unusual tire wear, no vibration.
And again, it's not just a plain old traction loss because it's happening on ramps I regularly did at 70+ with no drama. It also doesn't appear to happen at low speed.
Is it possible for the Torsen LSD to go bad or get damaged and do something like this? Just spitballin' here.
Dake is offline   Reply With Quote
Old 02-10-2018, 11:20 PM   #68
Brzlimited661
Very similar to what i experienced. Hold on now that i remember when i got the car the driveshaft was disconnected to tow it. I reinstalled it but i dont have a torque wrench could it be possible the bolts arent tight enough?
Old 02-11-2018, 12:17 AM   #69
Even if the bolts are loose they wouldn't cause your issue.
Not sure why you are so dead set against having the body checked but maybe you just simply still do not understand what the problem could be.
The car was written off in the first place because it would cost too much to repair so somebody someplace probably knew the frame was out.
The doors, fenders, hood, etc can be bent and not cause any issues with the structure.
If the A pillar is damaged it can throw off the whole body alignment. It is structural part of the car. Look at the picture below. That is the structural uni-body or "frame" of the car. See how the A pillar is tied directly to the front structure that holds the suspension?
If that pillar is bent that pressure extends through the rest and throws them out of alignment. A body shop will use special equipment to see that everything is in alignment. You can measure yourself but you need to be very precise in the measurements. You can not just look and say "ya it all looks good" http://what-when-how.com/automobile/...rs-automobile/
bcj (02-11-2018), humfrz (02-11-2018), Summerwolf (02-11-2018)
Old 02-11-2018, 12:43 AM   #70
Brzlimited661
Its not that im dead set on saying it isn't the frame but i feel a smarter cheaper possibly free way is to swap out my wheels and tires from a friend and rule the tires and rims out completely. I had him tell me it could be my cheap tires that are too stiff.
Car swaying left right (floating feeling) highway speeds FX86 Issues | Warranty | Recalls / TSB 37 05-30-2021 12:48 PM
Hood lift at high speeds Basti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 97 02-15-2016 04:50 PM
weird issue at high speeds after OFT tune dejxx Software Tuning 24 08-10-2014 10:49 PM
feeling a sway on the rear end qganja Scion FR-S / Toyota 86 GT86 General Forum 11 07-25-2013 04:56 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 06:25 AM
