Drives: 2013 Firestorm FR-S
Smartphone mount steady enough for track use
I'm looking at turning an old iPhone 6 into an oil/water temp gauge using the DashCommand OBDII app and wanted to know if anyone has suggestions on a mounting solution. Any thoughts? Would love to hear if anyone else uses a similar setup and how they like it.
#2 |
btr.life
Drives: 2022 GR86
Get a ProClip dash mount, they are great. I have used one in autocross for the past year and a half with an 8" tablet. Solid as a rock.
| The Following 2 Users Say Thank You to justinco For This Useful Post: | kravi (03-29-2017), vintagemxer (03-28-2017) |
#3 |
Ram mount.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
| The Following 2 Users Say Thank You to Jonsey For This Useful Post: | Kimsey47 (02-08-2018), Shark_Bait88 (03-28-2017) |
#4 |
Drives: Track preped NA FRS
I have a ram mount, have not had any trouble with it, that thing sucks! I mean, in a good way.
#5 |
I've been using a cheap ebay suction mount and it's never failed me at the track. I just clean the windshield and suction cup with some water before mounting, and to be extra safe, I put double-sided tape behind my device.
I know someone who uses the RAM mount for his phone and says it works well too.
2022 BRZ Build 2013 FR-S Build |
#6 |
Ohne Titel
Drives: 2017 BRZ PP ISM
A can tell you that a vent mount is not strong enough for HPDE. I bought a Ram mount recently, and have been experimenting with mounting on the front triangle section of the driver's side window. Got the phone mount that's a custom fit instead of the universal twist style. More secure: http://amzn.to/2nvfOMB
Still working on optimized routing for the power cable. Right now I have a 10 foot lightning cable running from the center console, under the seat and then tucked under the floor mat. |
#7 |
Pokemon Master
Drives: 2014 Scion FR-S
Scosche magic mount.
![]() '10 MazdaSpeed 3 Velocity Red Mica - SOLD PDM 2 '14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS |
#8 |
Drives: '13 FRS - STX
The ram mount suction cup is definitely strong enough, but the universal X-grip has a bit of slop in it, so no good if you're using the phone for accelerometer data, but likely good enough for most other uses.
ProClip looks good, and cheap, probably takes the cake if you want to run a tablet (autoxers running Solo Storm like Justin above), might have one soon. |
#9 | |
Drives: 1980 corvette, 2014 Subaru BRZ
#10 | |
The only time I've gotten shaky video off a suction cup mount (not ram) was when the suction cup was not properly secured. |
| The Following User Says Thank You to strat61caster For This Useful Post: | G-Man (03-29-2017) |
#11 |
Drives: Yes
Do you have a photo of your ProClip tablet set-up? I am going to try running some data this year, and I'd like to buy everything once. I have a 7" tablet and was going to get the mount for it, but I was worried it might not fit with where the ProClip dash mount is located in our car? Thanks.
#12 | |
btr.life
Drives: 2022 GR86
| The Following User Says Thank You to justinco For This Useful Post: | Biggins (02-07-2018) |
#13 |
Drives: Yes
Perfect, thank you! I was worried that the tablet mount would hit the radio.
#14 |
Drives: 2023 BRZ
| Matey's BReeZy. Slow and steady | Matey | Member's Car Journals | 23 | 08-23-2015 05:43 PM |
| Is your steering wheel steady ? | xtral | BRZ First-Gen (2012+) — General Topics | 6 | 08-16-2015 02:21 PM |
| Slow and Steady | Simok | Member's Car Journals | 5 | 02-06-2015 04:26 PM |
| Proper maintenance for a steady diet of e85 | Kronos | Software Tuning | 44 | 11-20-2014 01:43 PM |
| Car lurching at steady speed | batmobilefrs | Issues | Warranty | Recalls / TSB | 10 | 04-04-2014 08:33 AM |
