Old 01-19-2018, 04:04 PM   #15
Back on topic, yes, I've also noticed the same.
The upper vent blows hot when the mix is full cold with no AC. On my own I've just decided it's due to the black dash and that it just gets really hot in there.
Old 01-19-2018, 05:55 PM   #16
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I have to think at full cold with no AC the air is warm just because of how much heat our engines generate. I've noticed if I'm in motion the air will cool a few degrees, but still not comfortable, and once I stop it gets hot again as the ventilation sucks in hot air bleeding out from under the hood. When I first start the car and it isn't warm yet, I can get pretty chilly air from the vents, but once the car gets warm there is a notable change in the air temp from the vents, and even more of a change once you've stopped moving. Forces me to use the AC more often, as I'm not much of a window-open driver unless I'm autocrossing.
As for heat during the cold months, though, I really can't complain. I quickly reach a point where I have to lower the temp setting to keep from getting way too hot in the cabin.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Ultramaroon (01-19-2018)
Old 01-21-2018, 10:39 PM   #17
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Yes, the hot air even on cold setting is something I really don't like about the HVAC.
A lot of time the outside air would be the perfect temperature, but I still have to use AC because the vent blow hot air.
I dn't like opening the windows on the highway.
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Ultramaroon (01-21-2018)
Old 01-22-2018, 12:18 AM   #18
Yep, that's a common complaint, especially with owners of Miatas. Maybe it's a small, low, car thing .....
Old 02-04-2018, 11:20 PM   #19
BOND007_LTK
Drives: 2013 brz
Maybe the lower vent isn't being opened up all the way......
Have you been messen around under the dash lately ..??
Haven't messed around with anything. Didn't notice there is a vent there can be opened/closed for lower vents. I don't do recirculate.
I'm in Canada and it's cold right now. At around 0 degrees celcius. My heating system only kicks in after 10 minutes.
Will play around with it and mention it to dealer.
BOND007_LTK is offline   Reply With Quote
Old 02-05-2018, 01:24 AM   #20
Oh, I've noticed that my FR-S doesn't heat up the vent air for about 5-10 minutes ....... and it doesn't get real cold here.
Old 02-05-2018, 02:31 AM   #21
gravitylover
A couple of years ago there was a post about the low airflow out of the lower vents. If you get down there you'll see that it's a small opening and the air needs to blow over a bunch of parts, the cold coming through the tunnel is significant too and really cools the footwells. When it's super cold if you're on a long highway trip it's pretty much impossible to keep your feet warm. I've done a couple of long trips when it's in the single digits and it just plain sucks trying to keep my lower legs and feet comfortable.
Old 02-05-2018, 10:21 AM   #22
My grandson figured this out last winter. Even though there is plenty of warm air blowing on the feet it is countered by the cold air coming under the seat from the rear. I just wadded up a blanket and filled the gap under the driver seat and my feet get nice and toasty warm in a few minutes. Give it a try if you have cold feet.
gravitylover (02-06-2018), ZDan (02-06-2018)
Old 02-05-2018, 12:53 PM   #23
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Floor heat has never really worked that well in my BRZ. I love my Integra in the winter, it blows more air and more heat onto my freezing feet. Miss that feeling in the BRZ
Keep calm and drive safe
housecat is offline   Reply With Quote
Old 02-05-2018, 02:04 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
I test drove a few '17 BRZ Limiteds, they all seemed to be severely lacking in warm air for the feet bought one in spite of this, but it is pretty damn annoying...
Combating the heat toekneehair Forced Induction 823 12-23-2021 09:06 PM
FS: OEM Heat Shield MicheleAbbate Engine, Exhaust, Bolt-Ons 11 10-24-2018 07:24 PM
Heat cycled. forwallblakmail Tracking / Autocross / HPDE / Drifting 23 06-25-2014 11:45 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
