go_a_way1
Old 01-30-2018, 02:00 PM   #3641
The owl Talon
Would 18x8 wheels look flush with 225/40R18 tires? With stock suspension.
The owl Talon is offline   Reply With Quote
Old 01-30-2018, 02:08 PM   #3642
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by 671mike View Post
quick question will a 18x8.5 35 and a 18x9.5 35 fit with a front 245 rear 265 with tein s tech 1 inch drop coils
Welcome to the forum.
For rear fitment read the following.
Read post 213 and 214.
http://www.ft86club.com/forums/showt...=28017&page=16
Read page one of the Meaty tire thread.
http://www.ft86club.com/forums/showthread.php?t=41083
The front will need some camber to tuck the 245/35. Not sure if it is possible with camber bolts and natural camber from lowering. By s tech drop coils, I assume you mean s tech springs.
Read this stuff and decide if it is still a route you wan to go in. Anything is possible with enough work and parts.
Good luck!
I LIKE TIRES!
Old 01-30-2018, 02:12 PM   #3643
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x8 +45 front and rear on this page...
http://www.ft86club.com/forums/showt...?t=9471&page=2
18x8 +35 front and rear on this page...
http://www.ft86club.com/forums/showt...t=11393&page=2
I LIKE TIRES!
Old 01-31-2018, 01:03 AM   #3644
ShadowWolf_99
ShadowWolf_99's Avatar
Drives: 10 Series #895
Welcome to the Forum!
18x8 +45 MOTEGI RACING MR116 will work for your front. I have the same exact size wheels for my front with the same offset, though now I have added a 10mm spacer making them +35. I am using a 225/40/18 MPSS front tire.
If you want a wider tire for the rear, I would suggest getting a wider wheel. Like in the link below. I ran a 245/35/18 on an 18x8 and it was too wide. The 255/35 is not going to be a good fit.
I have 18x9 +37 rear wheels with a 245/35/18 MPSS tire. Since my set up is close to a 18x9 +35, (like in the link) I can tell you that it will fit a 245/35/18 tire lowered on tein springs. But a 255/35 is going to be close and may rub.
https://www.amazon.com/Motegi-Racing...I+RACING+MR116
Or get the 18x8 +45 all around with a 225/40 and call it a day. You can rotate the tires that way. Adding a 10mm front and a 15mm rear will make the wheels flush. (Or 15mm front and 20mm rear for a more aggressive look)
It really is about what you want out of the wheels and tires.
Happy to help.
Hey how wide can I go with the 18X8 all around. If go 235 or 245 of they won't rub.
Sent from my SM-G950U using Tapatalk
PDX86 / 86 Sessions / 86Squad / DarkSquad
ShadowWolf_99 is offline   Reply With Quote
Old 01-31-2018, 01:36 AM   #3645
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I would suggest 225/40 for 18x8 inch wheels. The other sizes will work too. 225/40 fits best, is the lightest weight, and will cost the least.
I LIKE TIRES!
Old 01-31-2018, 01:38 AM   #3646
ShadowWolf_99
OK sounds good. Thanks again.
Old 02-01-2018, 04:25 PM   #3647
671mike
Drives: 2015 frs
18x9.5 offset 35
Hello
I am looking at a set of 18x9.5 35 I have 1 inch drop Springs and would like to run a 235 or 245 on the front and a 255 265 on the rear is there anyone that can tell me if this will fit without having to change anything else
671mike is offline   Reply With Quote
Old 02-01-2018, 06:59 PM   #3648
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
will i be able to fit 17x9 +25 wrapped in 245/40/17 when lowered?
ImAdopted is offline   Reply With Quote
Old 02-02-2018, 01:26 PM   #3649
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Do you have coilovers? Or are you planning on springs? How aggressive do you want your camber?
17x9+25 sticks out 3.7mm more than a 9.5" +35 wheel. Look at post # 89 it will stick out approx. 4mm more than the pics in the link before lowered, and as you can see will need a bit of camber to tuck the fronts.
http://www.ft86club.com/forums/showt...t=15097&page=7
I LIKE TIRES!
ImAdopted (02-02-2018)
Old 02-02-2018, 01:42 PM   #3650
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
would be on coils. dont want super aggressive camber but willing to adjust to see what its like
thanks for the info/link, hmmm seems like the fronts stick out a little too far so if the 17x9 +25 will stick out more i think im better off with 17x9 +35
actually, i found these thread of 18x9 +25 and post #22 is actually kinda appealing to me so maybe i will reconsider
http://www.ft86club.com/forums/showt...t=37848&page=2
Old 02-07-2018, 02:17 PM   #3651
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Without aggressive camber...
via Imgflip Meme Generator
I LIKE TIRES!
ImAdopted (02-07-2018)
Old 02-07-2018, 02:55 PM   #3652
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
lol yeah after i found more pictures i definitely reconsidered and didnt fully know truly how much would need but ill just stay away from +25 aha
Old 02-12-2018, 03:55 AM   #3653
KDOS702
Drives: 2015 Scion FR-S
So I am getting the rallybacker v2 kit, and I can't decide what wheel specs to get to make it flush with stock camber. According to 86worx.com, the kit is supposed to add an extra 50mm up front and 85mm in the rear. Also, what tires would I need to run with little to no tire stretch. My car is currently dropped an inch on coilovers.
Thanks.
KDOS702 is offline   Reply With Quote
Old 02-12-2018, 08:46 AM   #3654
Fainten
Fainten's Avatar
Drives: white brz
I have 245/35/18 MPSS. I went with them because, they are the correct diameter, weigh 2lbs less than a 245/40, and have a larger contact patch.
I know Michelins are expensive, and that the 245/35 can cost more than a 245/40, but right now on Tirerack, they have Ventus Evo 12's for 150 each. (not bad )
I understand that if you are not going to lower you car, that you may want a taller tire to "eat up" some of the gap. If this is your logic, then go for the taller heavier tire. Most guys eventually lower their cars though...
Happy holidays! Glad I can help.
Hey Im trying to run 245/35 18 with a 9.5 rim but in stock height(for now) if i go with federal 245s 595 rs r would they fit good with no rubbing. I heard they run bigger
Fainten is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
