Old 01-20-2018, 04:35 PM   #29
highway7
Drives: FRS 2013
Originally Posted by ermax View Post
All my fluid leaked before it left the factory... is that a problem? Hahaha
Lemon Law
highway7 is offline   Reply With Quote
Old 01-22-2018, 06:15 AM   #30
howareyoukk
Drives: Gts86
UPDATE 4: Hi guys I think I am paranoid..so basically I walk pass the dealership every day after work and When I was passing the dealership today, I did not see the car that I test drove and I started wondering is it POSSIBLE that they somehow realised it was indeed a problem, instead of being a vehicle characteristic and they decide to check the demo car (the one I test drove), hence its gone, and not mine, since its a used model and I did not purchase from them.
In other words, is it possible that tried to comfort me and ultimately get rid of me by letting me test drive a demo car that has the same noise, but they realised its a problem and took away the demo car and fixed it
howareyoukk is offline   Reply With Quote
Old 01-22-2018, 10:59 AM   #31
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Anything is possible, best not to get that paranoid and worried about it. If you're concerned about something like that, bring it to a different dealer.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
howareyoukk (01-22-2018)
Old 01-22-2018, 11:25 AM   #32
Or maybe they just sold it? Car dealers tend to sell the cars on the lot.
howareyoukk (01-22-2018), humfrz (01-22-2018), Overdrive (01-22-2018)
Old 01-22-2018, 12:20 PM   #33
howareyoukk
Drives: Gts86
Yeah thats what I thought as well. it would be a hot sale if thats the case, since I test drove the car on a Friday and the dealership only opened till 1:00pm on Saturday and it closed on Sunday. And the car was gone on Monday...
Sorry for being irritating at this point but after doing some further readings on multiple forums tonight, I have found a video linked to a post, where it showcased my exact problem. It almost looked like I was the one who videotaped the issue myself ! unfortunately the person who started the post & video did not seem to find a solution from either youtube or the forum.
[ame="https://www.youtube.com/watch?v=gcvI-anyCX4&list=WL&index=155"]Frs engine problem - YouTube[/ame]
engine pining perhaps? I would also like to meet up with my local 86 group asap and see if I have the chance of test driving one of their 86's with AT. Either way I am pretty keen on finding out the cause of the rattles, whether its an abnormal behaviour with this car or not..I think I suffer from OCD syndrome....
The Following User Says Thank You to howareyoukk For This Useful Post:
Tcoat (01-22-2018)
Old 01-22-2018, 12:59 PM   #34
Vacuum pump.
http://www.ft86club.com/forums/showt...=107577&page=3
Old 01-22-2018, 01:22 PM   #35
Well, I'll go back to my first thoughts that something is vibrating when the engine is under load that is causing that vibration sound.
What I would do is to take my car up to the local automotive shop and request the oldest mechanic they have to take a ride with me and let him hear the noise.
Then suggest he put it on a rack and pound around the undercover panels with a rubber mallet to see if he can duplicate the noise. If not, take off the front under panel and bang around the exhaust heat shield with the rubber mallet ..... then do the same with the rest of the exhaust system.
Betcha he can find out what is making the sound ......... then take a crowbar to that piece and push it over.
WOW! ....... how hi tech ........
Old 01-22-2018, 01:55 PM   #36
howareyoukk
Drives: Gts86
thats what I thought as before test driving a demo car, perhaps a 2016 or 2017 demo model, at the Toyota dealership and it was making the same rattle under the same conditions. I am confused. this rattling noise is harder to solve than my engineering exams in university.
humfrz (01-22-2018)
Old 01-22-2018, 02:15 PM   #37
Ahhh .......haaaaa ......... NOW, we are getting the ....... rest of the story ......
I'm ah feared you are over engineering the problem ......... it's a simple rattle ....... NOT a complex piece of rocket engineering .......
Old 01-22-2018, 08:43 PM   #38
howareyoukk
Drives: Gts86
lol even with engineering I had survived the course aka graduated.
humfrz (01-22-2018)
Old 01-22-2018, 08:46 PM   #39
howareyoukk
Drives: Gts86
Originally Posted by jbsali View Post
I'm taking my car in for a transmission inspection this saturday based on almost the same noise. I'm expecting it to be a "normal" thing but want it checked out before my BRZ goes OOW.
I suspect its my flywheel that rattles. its odd though because its most noticeable at lower rpms, clutch not pressed. When the fans kick in, its more audible too.
How did your case go?
Old 01-22-2018, 08:51 PM   #40
Old 01-23-2018, 09:24 AM   #41
howareyoukk
Drives: Gts86
Update 5: solved the problem by plugging the sound tube from a reply suggested by a member of the forum, though I am still not sure what caused the rattle. The person gave me the advice called it a normal sound.
http://www.ft86club.com/forums/showthread.php?t=118348
Old 01-23-2018, 09:35 AM   #42
Yep. The sound tube is a glorified kazoo and the noises it creates are more annoying than anything.
Check your intake filter. I had a dry leaf that got sucked up in there that made the most bizarre (and absurdly loud) buzzing noise which baffled me for days.
howareyoukk (01-23-2018)
Metallic buzz over 4000 rpm? Ingen Issues | Warranty | Recalls / TSB 37 11-21-2017 02:51 PM
Trunk Buzz After Sub install Hawker271 Issues | Warranty | Recalls / TSB 5 12-13-2016 01:57 PM
Rattle/buzz with certain bass tones. Tyler. Electronics | Audio | NAV | Infotainment 6 05-03-2014 09:15 AM
Slight buzz at 1,500 RPM ericmpena Engine, Exhaust, Transmission 5 05-02-2014 09:35 AM
Anybody Have this Buzz/Rattle? Gary in NJ BRZ First-Gen (2012+) — General Topics 8 10-07-2013 01:36 PM
