#15 | |
Drives: FT86
Ive no idea what those dssport guys are on about, regarding the 5% limit on power increase, i think they were smoking something. However i suspect it was an interpretation by the person that wrote the article from info relayed by tuner. They probably meant you wont get more than about 5% increase by just chamging bolt on components without altering the tune. Not that the ecu somehow limited power increases to 5% Last edited by steve99; 01-10-2018 at 06:57 AM. |
#16 | ||
Anti stance.
All the air entering the system in a catless car it metered by the MAF, so little to no additional trimming will be needed, so unless the fuel injectors only support 20% more fueling demands over stock, that's a bogus number in this respect. However, it wouldn't take a very large leak to swing your fuel trims over 20%... |
#17 | |
The Dictater
Drives: '13 Red Scion FRS
I thought I remembered seeing a limiter on how much fuel trim was allowed. That's where my 20% upper and lower limit came from. |
#18 | |
Huge E85 fan!
Drives: 2016 Scion FRS
#19 |
Drives: 2013 Scion FRS
Thanks a lot for the replies guys. I’m thinking I might just put on the header since at least I’ll eventually get a tune at least. Plus I just DD this, not using it for any tracking or stuff like that. Very good info, glad to be a little wiser than yesterday
#20 |
Anti stance.
DD'ing with a MIL light on would aggravate me.
#21 |
#22 |
Anti stance.
You can reset the code, but you won't be able to turn it off. It will return until you have that specific MIL light muted with an actual tune.
#23 |
DDing without a cat would aggravate me.
#24 |
Drives: 2017 BRZ
Breathing is SO overrated.
#25 |
Drives: 2016 Subaru BRZ
#26 |
Drives: FT86
Yep im saying same thing , the ecu will continue to target same afr. All im sating is initially if the mods cause any fueling change the afr may vary slightly the ecu will detect the extra air flow and quicly alter fueling back to target using fuel trims
#27 |
Drives: FT86
#28 |
Drives: FT86
Driving with the mil\cel on will mask any other engine issues so not a good idea
| catless header vs catless frontpipe | steveholt | Engine, Exhaust, Transmission | 30 | 10-10-2017 07:13 PM |
| Should I get a tune for a catless exhaust system? | Astroboy | Forced Induction | 3 | 09-03-2014 08:11 PM |
| Fact vs Fiction: Catless front pipe (no tune) | BlueDubbinTDI | Engine, Exhaust, Transmission | 7 | 11-04-2013 10:11 PM |
| Critter with gears - why I love science! | bestwheelbase | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 09-15-2013 07:01 AM |
