Old 09-03-2014, 03:23 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Should I get a tune for a catless exhaust system?
I am running an ago turbo kit stage one with the base map. I have an all catless exhaust and was wondering if a tune was needed.....
Astroboy is offline   Reply With Quote
Old 09-03-2014, 04:17 PM   #2
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I am no FI expert but from what I have read and seen, you should only rely on the base tune to get you to a tuning shop, where you have someone do a custom tune. Correct me if im wrong FI folks.
A full catless exhaust was probably not used during the base tune so you would want to tune it anyways.
GotBRZ1691 is offline   Reply With Quote
Old 09-03-2014, 04:47 PM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Base maps are generally safe maps to run, so you might not blow anything up, but there's a decent amount of power to be gained by getting a custom tune tailored to your car. Unless of course it's a crappy base map
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 09-03-2014, 08:11 PM   #4
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
I have been on the AVO base tune, stage 1 kit with BOV and an Invidia catless resonated front pipe. The concept of a base tune with sufficient R&D equates to the "stock" tune. This should be able to tolerate a little change like going catless.
andrewFT86 is offline   Reply With Quote
Any1 catless with no resonators with Q300 exhaust? sissupr Engine, Exhaust, Transmission 7 04-08-2014 10:27 AM
FS: Invidia Catless exhaust set Jchonn Engine, Exhaust, Bolt-Ons 11 04-08-2014 09:55 AM
Fact vs Fiction: Catless front pipe (no tune) BlueDubbinTDI Engine, Exhaust, Transmission 7 11-04-2013 10:11 PM
SRT header back exhaust catless w/ tip A serial gixxer Engine, Exhaust, Bolt-Ons 6 12-04-2012 11:00 PM
