#519 | |
Drives: VA2 STI
Also, were the changes immediate or did it take time for the car to adjust? Last edited by CFutGwai; 12-24-2017 at 02:52 AM. |
#520 |
Huge E85 fan!
Drives: 2016 Scion FRS
I never changed the overrun rpm delta. I don't even know what that is TBH. The changes were immediate after I flashed the tune. Even cold my car popped just changing the B table you see above.
#521 |
Drives: VA2 STI
Hmm interesting.. i guess there's more to the 17',s then.. I can't seem to get any results..
#522 |
Huge E85 fan!
Are you catless? My 2016 is catless and the Works Muffler is fairly loud too.
#523 |
Drives: VA2 STI
#524 | |
Drives: 2017 BRZ Performance Package
EDIT: |
#525 | |
Drives: VA2 STI
#526 |
The same numbers as someone with a yellow FRS in here. Should be -15 in the .15 column and -6 in the .20 column. I also made it so that I get no pops under 3k rpm since it can get kind of loud in parking garages or when I’m downshifting next to a cop 😅.
#527 |
Drives: 2017 GT86
Ok so I can't figure this out. I have the same charts on my 2017 86 but it still cant produce any popping. I have an n1, Tomei UEL, and invidia FP fully catless. Can anyone clue me in? I'm starting to believe that it's because it's an automatic that it doesn't work.
#528 | ||
Drives: VA2 STI
![]() This did the trick for me.. now I can get the car to pop on command.. Time to fine tune and dial in the pops to something a little more acceptable ![]() Quote:
#529 |
Drives: 2017 GT86
In paddle shifter mode? And does it pop only when downshifting? And what do you mean .20 column?
#530 |
Huge E85 fan!
@steve99 Do you think or have experience with the pop & backfire tune modification damaging an engine? I think it'd damage cats over time (unburnt fuel is known to damage cats) but in an engine with no cats at all, can this tune do any damage?
I hear differing opinions and first hand experiences. I haven't read or heard about anyone with this tune actually doing damage, I have read about people running this tune just fine for a year or more. But I value your opinion over most- do you think it's safe? |
#531 | |
Drives: FT86
Ive been doing these tunes for people for two or more years. I dont do it on turbos only NA and i dont add fuel, i do ignition retard only. Ive not had anyone complain or come back, except for more pops usually. Its just doesnt work if you have stock catted header, doesnt rearly work with catted headers at all. Works ok with catless header and stock catred front pipe and a catback. As i dont add extra fuel just retard the fuel will be burnt late hence the pops. The pops obviously cause pressure spikes so its possible it could damage stock ceramic cats but had no one to date with an issue. Its also possible it could dislodge muffler packing material, but again not had any conplaints, must have done 30 plus people myself pluss suppied lots of tunes to people. Unlikely it would damage the aftermarket metalised cats. I always tell people it possible, but it does seem unlikely given the number of people doing tgis mod and the time frame of over two years. The stock tunes on these cars run extremly rich 10.7 afr at high rpm this we assume is to cool cats and extend their life or more likely their efficiency over time. Most tunes run about 12 afr so cats will likey get hotter than stock this is probably more likey tgis will reduce their efficiecy at converting gasses as well. |
#532 | |
Drives: 2017 GT86
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 04:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 05:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 07:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-17-2014 11:07 PM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 02:12 PM |
